17267 Discussions
PCIe IP example error: Failed to open design unit file "../../../top_core.vo" in read mode.
MMorr23
Hello, I cannot simulate the PCIe example from this PCIe doc "IP Compiler for PCI Express User Manual": https://www.intel.com/content/dam/www/programmable/us/en/pdfs/literature/ug/ug_pci_express.pdf
When I try to run the runtb.do script in Modelsim (To compile the testbench example), I get the error Failed to open design unit file "../../../top_core.vo" in read mode.
That file seems to not have been created on my computer... I don't know where it is supposed to come from.
I have purchased this Cyclone IV GX board with PCIe and cannot get any of the intel IP to simulate or build and run on this thing...
I am using Quartus 18.1 lite on windows 8.
Is there a better document for getting started with PCIe IP? Just want to simulate and observe the protocol working in Quartus.
Thank you very much :)
AnandRaj_S_Intel
Hi Matt,
Looks like working directory is too long. Can you retry after changing the directory length?
For document and example refer below links documents
https://www.intel.com/content/www/us/en/programmable/support/support-resources/intellectual-property/interface-protocols/pci-express/ips-inp-pcie.html
https://fpgawiki.intel.com/wiki/Category:PCI_Express
Anand
MMorr23
I tried shortening the directory to which Quartus restores the .qar file to just "D:/c/", but I still get this error:
# Model Technology ModelSim - Intel FPGA Edition vlog 10.5b Compiler 2016.10 Oct 5 2016
# Start time: 23:43:27 on Jul 30,2019
# vlog -reportprogress 300 "+incdir+../../common/testbench/+../../common/incremental_compile_module+.." -work work ../../../top_core.vo
# ** Error: (vlog-7) Failed to open design unit file "../../../top_core.vo" in read mode.
# No such file or directory. (errno = ENOENT)
# End time: 23:43:27 on Jul 30,2019, Elapsed time: 0:00:00
# Errors: 1, Warnings: 0
# ** Error: D:/intelFPGA_lite/18.1/modelsim_ase/win32aloem/vlog failed.
# Error in macro ./runtb.do line 115
# D:/intelFPGA_lite/18.1/modelsim_ase/win32aloem/vlog failed.
#   while executing
# "vlog +incdir+../../common/testbench/+../../common/incremental_compile_module+.. -work work $vfile"
#   ("while" body line 2)
#   invoked from within
# "while {[gets $simlist vfile] >= 0} {
#   vlog +incdir+../../common/testbench/+../../common/incremental_compile_module+.. -work work $vfile
#   ("eval" body line 3)
# "_comp"
anything else i can try? can you send me the correct top_core.vo file directly?
AnandRaj_S_Intel
Yes, I have able to replicate the scenario attached modelsim error log.
Let me check and come back.
Anand
MMorr23
AnandRaj_S_Intel
Still working on it.
we will update you soon.
​Sorry for the inconvenience caused.
MMorr23
AnandRaj_S_Intel
​Hi,
​Sorry for the inconvenience caused, Still working on it.
Meanwhile kindly check below links which have similar issue.
https://forums.intel.com/s/question/0D50P00003yyRkLSAU/how-to-rectify-modelsim-error-failed-to-open-topcorevo?language=en_US
Anand
