17263 Discussions
PHY IP Base-R Compilation Error Peak Memory
I am trying to use the SFP+ connectors from the 10G BASE-R megafunction on a Stratix V FPGA. I just want to connect the two SFP+ ports with a external cable and do BER testing on the system. However, when I try to compile the design with the PHY IP core, I get the error:
Error: Peak virtual memory: 844 megabytes
Can anyone help me with debugging this?
Enlarge your page file size on Windows.
Use a PC with a higher performance, specially more RAM.
