17264 Discussions
[SV] How does Quartus decide when to use registers? (after analyses and synthesis)
Hi everybody!
I have the following concern: I have a module with a single 5-bit variable defined as logic which I use inside an always_ff which increases it every clock cycle.
My question is: when I run the analyses and synthesis, why the number of registers (in the flow summary) is zero? When is it supposed to increase?
I thought a register would be a single 1-bit flip-flop, but it seems is not. I also couldn't find better information about these registers in the datasheet of my FPGA (cyclone iv e EP4CE115F29C7)
thank you if you can help me!
Have you connected the outputs from your design to some pins on the FPGA? without connecting it to the output, you will get no logic.
Nope, but in another design I didn't do it as well but in the flow summary it says that some registers were used. But the strange thing is the amount of them that is not right.
Here is the second one that takes 41 registers (please disregard the meaning of the code itself)
module seq_mul_add_2( input logic clock, reset, input logic X1, X2, Y, output logic Zo, output logic data_is_ready ); logic Z; logic k,l,m; always_ff @ (posedge clock) begin if( reset ) begin data_is_ready <= 0; k <= 0; l <= 0; m <= 0; Z <= 0; Zo <= 0; end else begin l++; if( l<=13 ) begin Z <= Z + X1 * X2; end if( l==14 ) begin l <= 0; Z <= 0; m++; data_is_ready <= 1; Zo <= Z + Y; end else data_is_ready <= 0; if( m==13 ) begin m <= 0; k++; end end end endmodule
