17257 Discussions
PLL reconfiguration not accepted
I'm having problems with a small part of a pretty big design. I want to phase shift a PLL output (Stratix II) and have instantiated megafunctions for PLL and PLL_RECONFIG and connected them like this:
// ======================================================================== // Signals // ======================================================================== wire scanclk, scandata, scanread, scanwrite, scandataout, scandone; wire reconf_busy, reconf_reset; wire pll_areset; wire data_in; // ======================================================================== // PLL_RX // ======================================================================== ext_pll_rx pll_rx_i ( .areset ( pll_areset ), .inclk0 ( hs_rx_clk ), .scanclk ( scanclk ), .scandata ( scandata ), .scanread ( scanread ), .scanwrite ( scanwrite ), .c0 ( c0 ), .locked ( locked ), .scandataout ( scandataout ), .scandone ( scandone ), .enable0 ( enable ), .sclkout0 ( sclkout ) ); // ======================================================================== // PLL_RX Reconfig // ======================================================================== pll_rx_reconfig pll_rx_reconfig_i ( .clock ( clk ), .counter_param ( 3'b010 ), .counter_type ( 4'b0100 ), .data_in ( data_in ), .pll_areset_in ( 1'b0 ), .pll_scandataout ( scandataout ), .pll_scandone ( scandone ), .read_param ( 1'b0 ), .reconfig ( phase_shift ), .reset ( reconf_reset ), .write_param ( write_param ), .busy ( reconf_busy ), .data_out ( ), .pll_areset ( pll_areset ), .pll_scanclk ( scanclk ), .pll_scandata ( scandata ), .pll_scanread ( scanread ), .pll_scanwrite ( scanwrite ) );But during Analysis & Synthesis I receive the following warning:
Warning: PLL "singlechannel:ch0_i|pll_rx_ps:pll_rx_ps_i|ext_pll_rx:pll_rx_i|altpll:altpll_component|pll" has scan reconfiguration ports connected, but PLL scan reconfiguration is not being used (since port SCANDATA is not connected) Warning: PLL "singlechannel:ch0_i|pll_rx_ps:pll_rx_ps_i|ext_pll_rx:pll_rx_i|altpll:altpll_component|pll" has port SCANCLK connected when PLL scan reconfiguration is not being usedI also get this:
Warning (14320): Synthesized away node "singlechannel:ch0_i|pll_rx_ps:pll_rx_ps_i|pll_rx_reconfig:pll_rx_reconfig_i|pll_rx_reconfig_pllrcfg_j0r:pll_rx_reconfig_pllrcfg_j0r_component|altsyncram:altsyncram3|altsyncram_f2r:auto_generated|q_a"Why would it not accept my connections? I've spent quite some time on this now and am getting pretty frustrated. Would be very thankful for any help on the matter!
BUMP
Nobody has seen this before??
I would expect a similar result, if any of the input ports to altpll_reconfig required to trigger a reconfiguration is stuck to an inactive level.
I found it, not sure which of the following measures that fixed it though:
Proper reset of altpll_reconfig (old one didn't need this)
Have a scan chain memory initialization file for the altpll_reconfig block
Slowed down reconfiguration clock from 20 MHz to ~1MHz
