17259 Discussions
Passing parameter/generic to the top level in Quartus/tcl?
I'm trying to pass a git sha1 as a parameter to the top level in Quartus tcl
I added a source probe:
gits u_gits (.probe (160'habbaface000000000000000000000000acdcbabe)); Which I can read with a small script:
./read-gits.sh GIT_SHA1: ABBAFACE000000000000000000000000ACDCBABE Then I do:
module top # ( parameter GIT_SHA1 = 160'h0) ( input wire pad_clk_50m_fpga, ... gits u_gits (.probe (GIT_SHA1));
./read-gits.sh GIT_SHA1: 3462636237316231396130366135366562373434 Which seem to be the ascii representation of the last 160 bits of the sha1
Inside the project file I have:
grep GIT_SHA1 project.qsf set_parameter -name GIT_SHA1 160'ha26916cc5fa8d5dbda994bcb71b19a06a56eb744 Then I tried to pass it as an integer
grep GIT_SHA1 project.qsf set_parameter -name GIT_SHA1 927200069134354371996170413995076949976682510148 But then I just got:
./read-gits.sh GIT_SHA1: 00000000000000000000000000000000FFFFFFFF
So what is the recommended way to pass a 160 bit vector to the top level as a parameter or generic using tcl in Quartus? Passing it as a string would result in control characters and would require some quoting of tcl delimiters
I'm not sure what you are trying to do here. If you are talking about synthesis, the parameter must be a set value at compile time. What does "read-gits.sh" actually look at and do? Are you talking about the In-System Sources & Probes debugging feature? It's a little confusing what's happening here.
Yes it's synthesis in Quartus (17.0.2), it's a constant known at synthesis time, and it's a probe as in-system sources & probes. The script is using a quartus_stp tcl script which is simply calling "start_insystem_source_probe" and "read_probe_data -value_in_hex".
To me it seems like Quartus can only pass 32-bit integers as parameters to the top level.
I can use pre processor defines in verilog, but in vhdl I would have to generate vhdl code containing the constants unless Quartus can handle the vhdl number syntax better. This is quite cumbersome, and I would expect parameters/generics to work in Quartus. It works fine in simulation (modelsim, ncsim, and vcs) as well as in Xilinx Vivado where I can write (where $sha1 is a tcl variable holding the 160-bit value):
set_property generic "GIT_SHA1=160'h$sha1"
My question is if there is a way to pass a parameter/generic of a given size larger than 32-bit?
Either if larger generics than 32 bit integer can be passed or not, isn't it much easier to generate a VHDL package or Verilog include file holding the parameters?
It's not difficult to generate rtl code, but to me it's much simpler to put
set_parameter -name GIT_SHA1 160'h$sha1
into my build script. It's actually already there. It just doesn't work. I already have the same structure in my other scripts for simulation and build for other vendors.
The answer is no. The passing of generics to top levels in quartus has been fairly limited for a long time. You're limited to strings, integers, booleans.
You could probably pass it in as a string and have the HDL parse the string into a sensible value. The annoying part you'll find though, is that Quartus doesnt support textio during synthesis, so you'll probably have to write your own conversion function.
Up to 32-bit integers... I find it a bit odd. They have a parser capable of parsing Verilog numbers so why not use this to parse the expression passed by the set_parameter tcl command.
In Verilog it's possible to use the pre-processor as a work around:
module top `ifdef M_GIT_SHA1 # ( parameter GIT_SHA1 = `M_GIT_SHA1) `else # ( parameter GIT_SHA1 = {20{8'h42}}) `endif ( input wire pad_clk_50m_fpga,
And then set:
set_global_assignment -name VERILOG_MACRO "M_GIT_SHA1=160'h$sha1"
in the build script, which yields:
$./read-gits.sh GIT_SHA1: 1B15850CADD9D969468FEE6669D86837E7B19239 $git rev-parse HEAD 1b15850cadd9d969468fee6669d86837e7b19239
Verilog numbers are not integers. Integers in Verilog are 32 bit 4 state values (0,1,X,Z). Reg can be any length, but it is not an integer.
I guess the restrictions come from system. And most people dont pass a lot into the top level.
Yes I know Verilog regs/wires/logic types can have other values than integers/0/1 and are arrays/vectors. I expected scalar constants to work as it works in all the other tools mentioned, and since Quartus has a parser which presumably can parse Verilog constants witch could be re-used to parse parameters/generics. But again Quartus seem to support only up to 32-bit integers which I tried as a work around for the git SHA1 I tried to pass (160-bit vectors). Things could of course get ugly when you start to pass enums, packed arrays, structs, and combinations of these (even though not so common in synthesis).
I think most tools are pretty consistant in what they support.
Modelsim and ActiveHDL only support basic top level generics - integers, strings, booleans, logic_vectors (as a string). They do not support passing in arrays or records/structs
zener
According to:
https://www.intel.com/content/www/us/en/programmable/quartushelp/17.0/mapIdTopics/jka1465598325723.htm
Quartus should support different data types in parameters.
A 160-bit parameter as a hex value can be set by using the following constant:
set_parameter GIT_SHA1 H"88fdebee854eea5898f7daa7b87dbc4e6acb3986"
If I pass this in Quartus Prime Version 20.1.1 Build 720 11/11/2020 SJ Lite Edition using a Cyclone V device as a target it works as expected:
In project.map.rpt I observe:
; Parameter Settings for User Entity Instance: Top-level Entity: |top ;
; Parameter Name ; Value ; Type ;
; GIT_SHA1 ; ec2a02b93595351d1cf538d44a3cf19fb441e311 ; Unsigned Hexadecimal ;
Also if it's passed down to other parameters I see it as:
; SHA1 ; 1110110000101010000000101011100100110101100101010011010100011101000111001111010100111000110101000100101000111100111100011001111110110100010000011110001100010001 ; Unsigned Binary ;
Also inserting this parameter into a read only register reads it back correctly.
However, if I move to Quartus Prime Version 20.4.0 Build 72 12/14/2020 SC Pro Edition using a Cyclone 10 GX target:
In project.syn.rpt I observe:
; Synthesis Default Parameter Settings ;
; Name ; Setting ;
; GIT_SHA1 ; H"ec2a02b93595351d1cf538d44a3cf19fb441e311" ;
; Parameter Settings for Top-Level Entity ;
; GIT_SHA1 ; 0000000000100000000000100000100100110101100101010011010100010000000100000000010100111000000001000100 <truncated> ; Unsigned Binary ;
It appears that the synthesis engine used by the two versions/devices handles this differently.
