17255 Discussions
Path Issues using Questa-Intel FPGA Simulator
PJ_Novak
When trying to run the Questa-Intel FPGA simulator with a .VWF file, I get this error message, (see attached).  Is it possible this is a result of Micosoft OneDrive being installed on my work Laptop?  I do not see this error on my home PC0 which does not run OneDrive.
RichardTanSY_Altera
The error message complain that the directory path can not be found. Check that the directory path is valid or try to change to a different project directory path.
https://www.intel.com/content/www/us/en/programmable/quartushelp/current/index.htm#msgs/msgs/eqneto_invalid_testbench_output_path.htm
Richard Tan
RichardTanSY_Altera
Richard Tan
RichardTanSY_Altera
Dropping a note to ask if my last reply was helpful to you.
Do you able to resolve the issue?
Richard Tan
RichardTanSY_Altera
Thank you for acknowledging the solution provided. I'm pleased to know that your question has been addressed.
Now, I will transitioning this thread to community support. If you have any further questions or concerns, please don't hesitate to reach out. Please login to ‘https://supporttickets.intel.com’, view details of the desire request, and post a feed/response within the next 15 days to allow me to continue to support you. After 15 days, this thread will be transitioned to community support.
The community users will be able to help you on your follow-up questions.
Thank you and have a great day!
Richard Tan
