17268 Discussions
Pin file not updating
I am updating/changing the pin assignments of a file.
All is fine and compiling, however, the pin file is not updating. All the old pins are still there. The new pins I assigned are there, but not assigned to a location.
Any idea why this is?
Thank you.
how did you assign those pins?
you use pin planner don't you?
Actually, i have not assigned the pins yet. But I do use pin planner and all I have done is erased old pin assignments and add new ones.
I am just wondering why the pin planner is still using the old pin assignments and not populating with the new ones.
I am not sure what is wrong for now.
could you past pin planner image like this.
