I get the following error when trying to generate HDL for a system:
Error: border: Error during execution of script generate_hps_sdram.tcl: seq: Error during execution of "{C:/intelfpga_lite/19.1/quartus/../nios2eds/Nios II Command Shell.bat} make all 2>> stderr.txt": child process exited abnormally
I am using Quartus Lite 19.1 and have installed the windows patch. I have also found another work around for older versions that needed to uncheck a Linux support setting as well. I thought that perhaps I had some incorrect setting but I tried a GHRD Qsys file for the DE10 Nano kit that I am using and this also failed with the same error. Help!!
- « Previous
- 1
- 2
- Next »
I installed WSL2 with Ubuntu 18.04 and ran the "sudo" commands listed above and everything worked with Altera v21.1
Link for reference: community.intel.com/t5/Intel-Quartus-Prime-Software/Platform-Design-tool-gets-error-when-generating-system-Error/m-p/638649#M59904
As stated before, this has seemed to work for several customers. Thanks Kenny!
Hi all,
today I have the same problem. The main reason is that I did not install Ubuntu 18.04 LTS on the Windows subsystem as described in the instructions as below. After I completed the following requirements, everything works fine.
I used the latest version 22.1.1 of Quartus on Windows 10.
** To install Ubuntu 18.04 LTS : https://www.intel.com/content/www/us/en/docs/programmable/683525/21-3/installing-windows-subsystem-for-linux.html
** To install Eclipse IDE: https://www.intel.com/content/www/us/en/docs/programmable/683525/21-3/windows-installation.html
- « Previous
- 1
- 2
- Next »
