17255 Discussions
Platform designer crash on save/save as
ASkar2
I am using Quartus Prima 18.1.0 Lite edition on WIN 10.
I have troubles with Platform Designer - it keeps crashing on every "save" or "save as" attempt. JRE fatal error report appears in the project folder, but not much of a help for me.
Anyone encountered similar problem or have suggestion where to look for solution?
ASkar2
Update: I have uninstalled 18.1 version and installed 15.1 (once run on WIN 10 without problems) and the problem persists (even worse)!
Now every time I try running Qsys from Quartus, it crashes almost immediately, not allowing to let me do anything.
I have no idea, where the problem may be, but after wasting the whole day, this is so frustrating.
I'd be grateful for any guidance here.
# A fatal error has been detected by the Java Runtime Environment:
# EXCEPTION_ACCESS_VIOLATION (0xc0000005) at pc=0x0000000057966adf, pid=4968, tid=5800
# JRE version: Java(TM) SE Runtime Environment (8.0_05-b13) (build 1.8.0_05-b13)
# Java VM: Java HotSpot(TM) 64-Bit Server VM (25.5-b02 mixed mode windows-amd64 compressed oops)
# Problematic frame:
# C [msvcr100.dll+0x36adf]
# Failed to write core dump. Minidumps are not enabled by default on client versions of Windows
# If you would like to submit a bug report, please visit:
#  http://bugreport.sun.com/bugreport/crash.jsp
# The crash happened outside the Java Virtual Machine in native code.
# See problematic frame for where to report the bug.
KennyTan_Altera
Thanks, it is great to hear that it had been resolve. I will make a documentation for this for the future customer.
