17249 Discussions
Please solve this problem
write a procedure that assigns consecutive binary numbers to its OUT BIT_VECTOR lines.the parameters of the procedure are an 8-bit target output and a TIME period.When called, it will assign sequential binary numbers from 0 to 255 to its target signal output. these numbers are distanced by the amount of the constant associated with the period parameter.you can use the utilities of the basic_utilities.
Nobody here is supposed to do your homework for you.
Write and post some code and then someone would possibly help in debugging it.
