Popup Message Sounds
I like to listen to music while I work. I can't figure out how to turn off all those sounds evertime a message appears (like when the fitter completes). I have only found 1 checkbox in the options and it does not help. Any ideas on how to disable ALL sounds?
Peter
is the alert sound at the OS level rather than actually in Quartus?
I am sure it is at the quartus level because I get different sounds depending on what tool completed (i.e. the sound is different when the fitter completes than when the assembler completes).
What OS and Quartus version are you using ?
The only checkbox i knew so far is located under the menue Tools -> Options -> Processing -> "Play sound when design processing is completed" but this one is disabled by default as far as i know.
I am using Wndows 7, QII v 9.1
