I am currently trying to get a power estimate for my design using the PowerPlay Power Analyzer. But every time I run the Analyzer I get the following error.
PowerPlay Power Analyzer (quartus_pow) cannot be run. It requires a successful run of the Assembler. The Assembler (quartus_asm) failed or was not run. But actually I compiled the whole design successfully including the assembler. Any guess what could be the problem? Thanx for your help!Link Copied
What device? Do you see the assembler actually run? Possibly Assignments -> Settings -> Compilation Process -> Run Assembler During Compilation(this is on by default, but some people turn it off to save compile time).
It's the Cyclone III EP3C25F324C8. Yes I see it running through the compilation, also the box is checked and even if I run it separately again it does not work.
