Quartus/ModelSim
I'm wondering how one would get a post place and route timing analysis from Quartus and get it into ModelSim for analysis.
Thank you,
Rob
The EDA Netlist Writer does the job. Depending on the Quartus version the writer is enabled per default or not. From the menu, select Assignments > EDA tool settings > Simulation and select ModelSim-Altera. You can also choose where to store the netlist and the sdo-file that contains the delay information.
Much fun!
