17264 Discussions
Probem in a state machine code
Hi, I'm new in VHDL and I have a problem with this code:
The problem is that when I program it on The FPGA, even when SW(4) is equal to 0, LEDR(0) is equal to 1. And It stays on this state even if I move on the others switches (SW(0),SW(1),SW(2)).
Thank you very much for any help.
I didn't look at your code, but you should check your board documentation to see if the switches or LEDs are wired as active low rather than active high.
--- Quote Start ---
--- Quote End ---
I have already done it. They are active high.
Have you written a simulation testbench?
Why have you used > to compare the switch values?
--- Quote Start ---
--- Quote End ---
No, I didn't write a simulation testbench. I've just tested this code on the FPGA.
Actually, I didn't write the code. It is automatically generated by HDL coder based on a state machine in Matlab/Simulink. That's why > are used. But, I've tried ='1' to compare the switch values and it leads always to the same results : the code doesn't work.
Please, any help ?
Have you assigned the correct pins to the ports?
--- Quote Start ---
--- Quote End ---
Yes, I absolutely did.
The problem can't be in the syntax of clk_50 ? Shouldn't I write clock_50 rather than clk_50 ?
if there was a syntax error, it would be obvious.
Have you got the clock connected?
--- Quote Start ---
--- Quote End ---
Yes, the clock is connected.
