hidden text to trigger early load of fonts ПродукцияПродукцияПродукцияПродукция Các sản phẩmCác sản phẩmCác sản phẩmCác sản phẩm المنتجاتالمنتجاتالمنتجاتالمنتجات מוצריםמוצריםמוצריםמוצרים
Problem FSM
gomezramones
There is a problem that when I tried to design a FSM, the code never enters to that part. I simulated the same code in ModelSim and it was working fine.
FSM_I2C : process(current_state,next_state,i2c_start,Flag,i2c_clk_previous_internal, id2c_scl_i_clock,i2c_sda_oe)
	begin
		--if (RISING_EDGE(Clk)) then
			case current_state is
				when IDLE =>
					counter_variable <= 7;
					if i2c_start = '1' then
						next_state <= START;
						i2c_sda_oe <= '1';
					else
						next_state <= IDLE;
					end if;
				when START =>
					if Flag = '1' then
						i2c_sda_wr <= '0';
						next_state <= ADDRESS;
					end if;
				when ADDRESS =>
					if counter_variable /= 0 then
						if id2c_scl_i_clock = '1' and i2c_clk_previous_internal = '0' then
							counter_variable <= counter_variable - 1;
							i2c_sda_wr  <= I2C_ADDRESS_SENSOR(counter_variable-1);
						end if;
					else
							i2c_sda_wr  <= I2C_WRITE_RW;
							next_state <= ACK;
						end if;
					end if;
				when ACK =>
					i2c_sda_oe <= '0';
					if i2c_clk_previous_internal = '0' and id2c_scl_i_clock = '1' then
						next_state <= IDLE;
					end if;
				when others =>
					next_state <= IDLE;
			end case;
		--end if;
	end process FSM_I2C;
this is just a part of the I2C algorithm. In this case, I'm just implementing sending the address to see if my code is working fine. However, this is the output
Only works when I put inside the FSM a conditional IF(RISING_EDGE(CLK)), but I don't understand why since I'm updating all the variables in other process.
	process (Clk,reset_reset_n)
	begin
		if reset_reset_n = '0' then
			current_state 		 		<= IDLE;
			id2c_serial_scl	  		<= '0';
			id2c_serial_sda	   	<= '0';
		elsif (RISING_EDGE(Clk)) then
			current_state 		 		<= next_state;
			id2c_serial_scl			<= i2c_clk_previous_internal;
			id2c_serial_sda		 	<= id2c_serial_sda_o_internal;
			id2c_scl_i_clock 			<= i2c_clk_previous_internal;
		end if;
	end process;
gomezramones
The problem was not the triggered in the FSM. When you have a FSM and some signals are going to change in some cases, you need to initialize them at the beginning so the FSM can see signals change in every case possible.
ShengN_Intel
Could you provide a sample project for testing out.
Can also provide personally to my email qi.sheng.ng@intel.com
Sheng
gomezramones
 I forwarded you the project to your email
ShengN_Intel
By using the comparison trigger condition, i'm getting the signal tap waveform below (image):
May check out this video https://www.youtube.com/watch?v=WJFKBWCnAB4&t=1026s for the trigger condition details. I had sent the project file to your email.
For those red coloured signals are not in the node list due to being optimized away. But can try to preserve those signals by using keep or preserve attribute check this link https://www.intel.com/content/www/us/en/docs/programmable/683552/18-1/signal-preservation.html. However, I try with keep attribute on next_state signal but that affected the waveform result.
Sheng
p/s: If any answer from the community or Intel Support are helpful, please feel free to give best answer.
ShengN_Intel
Let me know if any further update or concern?
Sheng
gomezramones
