17268 Discussions
Problem compiling Hello_World host
I'm pretty new with OpenCL and I'm trying compiling hello world demo for cyclone v on Windows 10 - Quartus Prime 16.1.2 - OpenCL SDK - 16.1.2 - EDS 16.1.0.
So far I have been able to compile the aocx kernel both c5soc and for emulation, my problem comes when I try to compile the host application. I use Altera Embedded Command Shell and just type make -f makefile command, and the result is as follows:
c:/intelfpga/16.1/embedded/ds-5/sw/gcc/bin/../lib/gcc/arm-linux-gnueabihf/4.8.3/../../../../arm-linux-gnueabihf/bin/ld.exe: warning: libacl_emulator_kernel_rt.so, needed by C:\intelFPGA\16.1\hld\board\c5soc\arm32\lib/libalteracl.so, not found (try using -rpath or -rpath-link)
I configured environment variable ld_library_path as c:\intelfpga\16.1\hld\board\c5soc\arm32\lib expecting to solve the problem but didn't work.
See my last posts in https://www.alteraforum.com/forum/showthread.php?t=47354 and https://www.alteraforum.com/forum/showthread.php?t=42985&p=234676#post234676
For C-V A(I) have a problems with destination OS detection.
You want host on PC-Windows ? Or ARM-Linux ? Or PC-Linux ? In Windows-PC ?
Linking of libalteracl.so + libacl_emulator_kernel_rt.so in error output say about trying the way for compile application for PC-Linux, Windows want .lib-s.
