Problem with Alignment
Hey ,
I got the warning message about "Non Using DMA for transfer ... lack of alignment".
The data structure I used looks like as follows :
typedef struct{
double test1 , test2;
int test3;
}Test;
typedef struct{
double temp1;
double temp2;
double temp3;
double temp4;
Test temp5[256];
Test temp6;
}temp;
And I add the " __attribute__((aligned(64))) " in host and kernel like as shown :
typedef struct{
int test3;
}Test;
typedef struct{
double temp1;
double temp2;
double temp3;
double temp4;
Test temp5[256];
Test temp6;
}temp;
Then I executed the program and the warning message still happened and segmentation fault.
It seems that the data can't not transfer between host and FPGA , and the program will be stopped.
Could anyone help me , please : (((
You probably need to manually align the data structure on the host side for example, using posix_memalign.
temp tmp_struct;
posix_memalign((void**)&tmp_struct, 64, sizeof(temp));
