Hello everybody
I am using DE1-SOC board and I want to simply read and write to SDRAM from FPGA without using NIOS or HPS. Can you please let me know where can I find an example?Link Copied
Use your favorite web search engine and search for altera de1 sdram. One ofmthe fist results should be some Altera references.
You can use QSys to instantiate a SDRAM controller and use it with Avalon Bus in your code
Take a look at the demonstration called DE1_SoC_SDRAM_RTL_Test on the DE1_SOC system CD. It looks like exactly what you want. If you don't have the CD you can download it from the Terasic web site.
