17255 Discussions
Problem with MegaWizard Memory Compiler
I am trying to compile a dual port RAM block using MegaWizard and use the M4K blocks for the memory. When I start a new project and simply create a RAM block and synthesize design, it uses the memory bits without any problems; outputting this compilation report: Total memory bits: 16,384 / 239,616 (%7)
But when I try to do the same thing in my existing project where I am trying to do some audio processing using the WM8731 audio codec, the memory is not used. According to the report after synthesis, 0 bit is used.
I couldn't figure out what the problem is.
Any help will be appreciated greatly.
Thanks in advance
Problem solved, thanks.
I am experiencing the same problem.
How did u solve it?
