17267 Discussions
Problem with Synthese in Quartus with Customer-IP vhdl-file
Hi All,
I make a Customer IP and when I wont make a synthese, I have following error-message:
Error (10820): Netlist error at ime_avalon_xy_detector.vhd(109): can't infer register for count_hsync[1] because its behavior depends on the edges of multiple distinct clocks
In the attachment you find the entire vhdl file. The problematic part is in the xy_coordinate : process.
In HDL-Designer and QuestaSim I could make a success simulation. But the stimuli does not affect the same as in quartus II.
But I need the signal as in the simulation (the last 5 waves in pdf file).
How I can make a process with multiple distinct clocks?
Thanks you...
Hi Antonio,
You use two clocks in one process (coe_iVHA_HS and coe_iVGA_CLK). Like you said that could work in simulation, but how would a hardware implementation look like?
I would make a seperate process for the flag_hs signal, which look like:
process(coe_iVGA_HS, coe_iRST_N, reset_hs_flag)
begin if coe_iRST_N = '0' or reset_hs = '1' then
flag_hs <= '0';
[/INDENT] elsif(coe_iVGA_HS = '1' AND coe_iVGA_HS'event) then
flag_hs <= '1';
[/INDENT] end if;
end process;
define a signal reset_hs_flag and change
line 112 to reset_hs_flag <= '0';
line 125 to reset_hs_flag <= '1';
Remove lines 116 and 117.
I dont know if coe_iVGA_HS and coe_iVGA_CLK are asynchronous. If they are, take measures for clock domain crossing.
Succes, Ton
yes it works well now... ;O)
Thanks you very much.
Hi std_logic_vector
<< I dont know if coe_iVGA_HS and coe_iVGA_CLK are asynchronous. If they << are, take measures for clock domain crossing.
coe_iVGA_HS and coe_iVGA_CLK are synchronous, that are not problem...
Bye ;)
