17263 Discussions
Problem with generate statement in Verilog
I want to instantiate different modules controlled by an input "Mode".
Here are my code in Verilog:
generate case (Mode) 1: begin : case1
(instantiate module 1)
end
0: begin : case0
(instantiate module 0)
end
endcase
[/INDENT]endgenerate
Quartus II 9.1 gives an error
Error (10734): Verilog HDL error at Test.v(215): Mode is not a constant.
Does generate statement only use constant as conditions?
--- Quote Start ---
--- Quote End ---
Obviously. Generate means building a particular design part once or repeatedly, or omit it. This must be determined at compile time. What do you want to achieve?
I try to make it work with different plug-in devices which require different timing signals. It seems the only way I can do is to instantiate both modules and use muxers.
