17255 Discussions
Problem with the 7 segment display
Hello everybody,
I need to show a float point number in 7 segment display, but the dot doesn't have a pin to associate in the pin planner.
Somebody know how can I set the dot on 7-seg displays?
Thank you all.
which kit are you working with ?
Did you check the pinout of your kit and/or the reference manual ?
Are you sure that your display has dots ?
regards,
