17254 Discussions
can't infer register because its behavior depends on the edges of multiple clock
Hi
i wrote this vhdl code in Quartus II version 7.2 but when i want to compile it this error is displayed
can't infer register for flag because its behavior depends on the edges of multiple distinct clocks
i sure this code true because i wrote this code in modelsim software and xilinx-ise and simulated . it worked properly
what is wrong ?
please help me
library ieee;
use ieee.std_logic_1164.all;
use ieee.std_logic_unsigned.all;
use ieee.std_logic_arith.all;
entity delay is
port(
clk :in std_logic;
change :in std_logic;
output :out std_logic
end delay;
architecture behavior of delay is
signal flag : std_logic;
signal counter :integer range 0 to 100000;
begin
process(change, clk)
begin
if(rising_edge(change))then
flag <= '1';
output <= '0';
counter <= 0;
else
if(rising_edge(clk))then
if(flag = '1')then
if(counter < 100000)then
counter <= counter + 1;
output <= '0';
else
output <= '1';
flag <= '0';
end if;
end if;
end if;
end if;
end process;
end behavior;
Hi abbasi,
you are trying to make conditions with two edges : "clk" and "change" !
This is not proper and may be this is what the tool can't synthetize.
regards,
Yes exactly. This code works well in a simulator, but not in a synthesizer because the FPGA hardware can't do what you are describing. A clocked process can only depend on the edge of a single clock, just as a FPGA hardware register only has one clock input.
Hi thank you for your attention.
i want to enable counter with "change" signal and increase counter with clk rising_edge
and when "change" signal enabled again reset the counter and output signals.
in other hand i want to build a delay for output in code when change signal is enable for one clock.
but i dont know different code from this
how should i do this ?
please help me..
all the best for you..
The usual way to do this is to clock your process only on the rising edge of the "clk" signal, and sample your "change" signal in a register. You can call the sampled signal "prev_change" for example. Then you can compare the previous and the current value of the signal. If "prev_change" is '0' and "change" is '1' then you know you had a rising edge on "change".
Hi
I wrote this code in Quartus and simulate it. it was worked very well
thank you very much
entity delay is
port(
clk :in std_logic;
end delay;
architecture behavior of dead_band_generation_logic is
signal flag_a : std_logic :='1';
signal prev_change :std_logic ;
begin
process(clk)
begin
if(falling_edge(clk))then
if(flag_a = '1')then
prev_change <= change;
flag_a <= '0';
elsif(flag_a = '0')then
if(prev_change = '0' and change = '1')then
flag <= '1';
counter <= 0;
output <= '0';
end if;
end if;
if(flag = '1')then
if(counter < 25)then
output <= '0';
else
output <= '1';
flag <= '0';
end if;
end if;
end if;
end process;
end behavior;
