- Marquer comme nouveau
- Marquer
- S'abonner
- Sourdine
- S'abonner au fil RSS
- Surligner
- Imprimer
Hi all
I'm having some trouble while trying to import a logic lock region into a new design. I got two design partitions, one of them gets imported without any issues, it appeas as "locked" and the correct fixed size, but the second one appears as "floating" and "undetermined" size. The procedure I've taken to export/import both of them was the same. Any tip on what I may be missing here? Thanks in advance.- Balises:
- Intel® Quartus® Prime Software
Lien copié
3 Réponses
- Marquer
- S'abonner
- Sourdine
- Surligner
- Imprimer
--- Quote Start --- Hi all I'm having some trouble while trying to import a logic lock region into a new design. I got two design partitions, one of them gets imported without any issues, it appeas as "locked" and the correct fixed size, but the second one appears as "floating" and "undetermined" size. The procedure I've taken to export/import both of them was the same. Any tip on what I may be missing here? Thanks in advance. --- Quote End --- Hi, did you try to import two times the same partition into to your main project or a you talking about two different partitions ? Did have a look to your warnings ? Did you import placement and routing or the netlist only ? Kind regards GPK
- Marquer
- S'abonner
- Sourdine
- Surligner
- Imprimer
Hello
- They are two different partitions; - No warnings regarding partitions or logic lock; - I've tried both, placement & routing and netlist only Anyway, I've implemented a workaround and created a new partition instead of exporting the older one. Some additional work on adjusting, but it worked fine. No idea on why the second imported partition does not appear as locked. Thanks and regards- Marquer comme nouveau
- Marquer
- S'abonner
- Sourdine
- Surligner
- Imprimer
--- Quote Start --- Hello - They are two different partitions; - No warnings regarding partitions or logic lock; - I've tried both, placement & routing and netlist only Anyway, I've implemented a workaround and created a new partition instead of exporting the older one. Some additional work on adjusting, but it worked fine. No idea on why the second imported partition does not appear as locked. Thanks and regards --- Quote End --- Hi, I saw this effect also, but only in case that both partitions tried to use the same resources. Do you have an overlap of the logiclock regions ? Kind regards GPK
Répondre
Options du sujet
- Marquer le sujet comme lu
- Marquer
- S'abonner
- Page imprimable
