17267 Discussions
Problems instantiating qsys component within VHDL help
I have generated a Nios II system with qsys and am trying to write a top-level VHDL which wraps it as shown below but I am getting the following errors. CLOCK_50 , KEY and SW are the exact sames in the nios_qsys.v generated from qsys so I don't know what the issue is. Does anyone know how to solve it? Thanks
Error (10349): VHDL Association List error at lights.vhd(35): formal "clk_clk" does not exist
Error (10346): VHDL error at lights.vhd(33): formal port or parameter "CLOCK_50" must have actual or default value
Error (10784): HDL error at lights.vhd(25): see declaration for object "CLOCK_50"
Error (10346): VHDL error at lights.vhd(33): formal port or parameter "KEY" must have actual or default value
Error (10784): HDL error at lights.vhd(26): see declaration for object "KEY"
Error (10346): VHDL error at lights.vhd(33): formal port or parameter "SW" must have actual or default value
Error (10784): HDL error at lights.vhd(27): see declaration for object "SW"
LIBRARY ieee; USE ieee.std_logic_1164.ALL; USE ieee.std_logic_unsigned.ALL; ---------------------------------------------------------------------------------------------------------------- ENTITY lights IS PORT ( CLOCK_50 : IN STD_LOGIC; KEY : IN STD_LOGIC_VECTOR (0 DOWNTO 0); SW : IN STD_LOGIC_VECTOR (7 DOWNTO 0); LEDG : OUT STD_LOGIC_VECTOR (7 DOWNTO 0) ); END lights; ------------------------------------------------------------------------------------ ARCHITECTURE lights_rtl OF lights IS COMPONENT nios_qsys PORT ( SIGNAL CLOCK_50: IN STD_LOGIC; SIGNAL KEY : IN STD_LOGIC_VECTOR(0 DOWNTO 0); SIGNAL SW : IN STD_LOGIC_VECTOR (7 DOWNTO 0); SIGNAL LEDG : OUT STD_LOGIC_VECTOR (7 DOWNTO 0) ); END COMPONENT; BEGIN NiosII : nios_qsys PORT MAP( clk_clk => CLOCK_50, reset_reset_n => KEY(0), switch_in_export => SW(7 DOWNTO 0), led_out_export => LEDG(7 DOWNTO 0) ); END lights_rtl;
You've got the port mapping the wrong way round, it needs to be
port => local_signal
But the code you posted doesnt have signals called "clk_clk" , reset_reset_n, switch_in_export or led_out_export. Where do these come from?
Also, when mapping VHDL to a verilog component, you must get the case sensitivity correct.
If you are trying to simulate the Qsys design with your top level, you need to generate the simulation files and then change the tcl script to include your top level. It will compile all the files needed for the qsys system.
