17255 Discussions
Problems trying to configure three FPGAS using the EPC16
The aim of this thread is to request help from you guys because I have a problem trying to make a .pof file which is driving me crazy.
I am working on a card which has three FPGA (each one running different configuration files), I produced the .sof files and I successfully tested programing the FPGA using a jtag cable.
Now I would like to create a .pof file (for keeping the new FPGA personality in the non-volatile flash, in this case an EPC16), here is where my problem starts...
Using the "convert programming files" tool I produced a .pof file from the three .sof files (one for each FPGA) but for a reason which I cannot understand the FPGAs are not programed (done line does not go high) when I power cycle the card.
Do you have a clue, suggestion or hint which allows me to get rid of this problem and finally produce a working pof for the EPC16?
Your help will be more than welcome!
some extra data:
The three FPGA should be programmed using the 1-bit passive serial mode
I am using Quartuss II, Version 11.0
attached you will find some screen captures that shows how I am using the "convert programming file" tool.
--- Quote Start ---
--- Quote End ---
For multi-device configuration chain, add the SOFs according to the order of the devices in the chain.
Check the status of MSEL pin & other configuration signals.
Check jumper settings on a card.
Refer the following document for the “Conversion of SRAM Object File to Programmer Object File for Parallel Flash Devices”
https://www.altera.com/content/dam/altera-www/global/en_us/pdfs/literature/an/an478.pdf
Best Regards
Vikas Jathar
(This message was posted on behalf of Intel Corporation)
