17267 Discussions
Problems with FSM's and Counters
I'm having some major problems with this VHDL code. It's supposed to simulate an intersection traffic lights but the behavior that the waveform exhibits doesn't make any sense for the simplest cases. All it should do is alternate between the states for the amount of time given. 16 clock cycles for all of NS split among two states and 8 clock cycles for all of EW split among two states. The waveform behavior is not correct at all, certain states trigger when they shouldn't ie I should never have a Red light for NS and a green light for NS at the same time.
LIBRARY ieee; USE ieee.std_logic_1164.all; USE ieee.numeric_std.all ; ENTITY TrafficLight2 IS PORT(NS,EW,NSL,EWL: IN STD_LOGIC_VECTOR(1 DOWNTO 0);--cars that want to go in those directions Clk,Reset: IN STD_LOGIC; GNS,GEW,RNS,REW,GNSL,GEWL: OUT STD_LOGIC);--GNS = greens for North and South, GEW = greens for East and West, GNSL = greens for North and South left lanes, GEWL = greens for East and Weset left lanes END TrafficLight2; ARCHITECTURE Behavior OF TrafficLight2 IS TYPE State_type IS(NSStart,EWStart,GoNS,GoEW,GoNSL,GoEWL);--GoNS=North and South green,GoEW=East and West green,GoNSL=North Left and South Left green,GoEWL=East Left and South Left green SIGNAL state: State_type; SIGNAL count: INTEGER RANGE 0 to 16; BEGIN PROCESS(Clk) BEGIN IF Reset = '1' THEN state<=NSStart; ELSIF(Clk'EVENT AND Clk='1') THEN CASE state IS WHEN NSStart => count <= 16; state <= GoNS; WHEN EWStart => count <= 8; state <= GoEW; WHEN GoNS => IF count=8 THEN state <=GoNSL; ELSE count <= count - 1; END IF; WHEN GoEW => IF count=4 THEN state <=GoEWL; ELSE count <= count - 1; END IF; WHEN GoNSL => IF count=0 THEN state<=EWStart; ELSE count <= count -1; END IF; WHEN GoEWL => IF count=0 THEN state<=NSStart; ELSE count <=count-1; END IF; END CASE; END IF; END PROCESS; GNS<='1' WHEN state = GoNS ELSE '0'; GEW<='1' WHEN state = GoEW ELSE '0'; RNS<='1' WHEN state = GoEW OR state = GoEWL ELSE '0'; REW<='1' WHEN state = GoNS OR state = GoNSL ELSE '0'; GNSL<='1' WHEN state = GoNSL ELSE '0'; GEWL<='1' WHEN state = GoEWL ELSE '0'; END Behavior;
It appears to me that your fsm euns through the stages very well, but I do not see, where the inputs are set.
you need to have two processes to control your state machine, one is using for switching another for decoding
I'm not really sure what you mean by that but I did some cleaning up, the problem is that there are random blips that seem to pop up for no reason. Here's my code and a waveform to show what I'm talkin about.
http://img209.imageshack.us/img209/2018/samplelq6.jpg
LIBRARY ieee; USE ieee.std_logic_1164.all; USE ieee.numeric_std.all ; ENTITY TrafficLight2 IS PORT(NS,EW,NSL,EWL: IN STD_LOGIC_VECTOR(1 DOWNTO 0);--cars that want to go in those directions Clk,Reset,EmNS,EmEW,EmNSL,EmEWL,PEW,PNS: IN STD_LOGIC; GNS,GEW,RNS,REW,GNSL,GEWL,YNS,YEW: OUT STD_LOGIC);--GNS = greens for North and South, GEW = greens for East and West, GNSL = greens for North and South left lanes, GEWL = greens for East and Weset left lanes END TrafficLight2; ARCHITECTURE Behavior OF TrafficLight2 IS TYPE State_type IS(NSStart,EWStart,GoNS,GoEW,GoNSL,GoEWL,Em);--GoNS=North and South green,GoEW=East and West green,GoNSL=North Left and South Left green,GoEWL=East Left and South Left green SIGNAL state: State_type; SIGNAL count: INTEGER RANGE 0 to 31; BEGIN PROCESS(Clk) BEGIN IF Reset = '1' THEN state<=NSStart; ELSIF(Clk'EVENT AND Clk='1') THEN CASE state IS WHEN NSStart => count <= (TO_INTEGER(UNSIGNED(NS))+TO_INTEGER(UNSIGNED(NSL)))*4+4; state <= GoNS; WHEN EWStart => count <= (TO_INTEGER(UNSIGNED(EW))+TO_INTEGER(UNSIGNED(EWL)))*4+4; state <= GoEW; WHEN GoNS => IF EmNS ='1' OR EmEW ='1' OR EmEWL ='1' OR EmNSL = '1' THEN state<=Em; ELSIF count= TO_INTEGER(UNSIGNED(NS))*2+2 THEN state <=GoNSL; ELSIF PEW='1' THEN count <= count - 2; ELSE count <= count - 1; END IF; WHEN GoEW => IF EmNS ='1' OR EmEW ='1' OR EmEWL ='1' OR EmNSL = '1' THEN state<=Em; ELSIF count=TO_INTEGER(UNSIGNED(EW))*2+2 THEN state <=GoEWL; ELSIF PNS='1' THEN count <= count - 2; ELSE count <= count - 1; END IF; WHEN GoNSL => IF EmNS ='1' OR EmEW ='1' OR EmEWL ='1' OR EmNSL = '1' THEN state<=Em; ELSIF count=0 THEN state<=EWStart; ELSIF PEW='1' THEN count <= count - 2; ELSE count <= count -1; END IF; WHEN GoEWL => IF EmNS ='1' OR EmEW ='1' OR EmEWL ='1' OR EmNSL = '1' THEN state<=Em; ELSIF count=0 THEN state<=NSStart; ELSIF PNS='1' THEN count <= count - 2; ELSE count <=count-1; END IF; WHEN Em=> IF EmNS ='1' OR EmEW ='1' OR EmEWL ='1' OR EmNSL = '1' THEN state<=Em; ELSE state<=NSStart; END IF; END CASE; END IF; END PROCESS; GNS<='1' WHEN (state = GoNS OR EmNS ='1') ELSE '0'; GEW<='1' WHEN (state = GoEW OR EmEW ='1') ELSE '0'; --YNS<='1' WHEN (count = 1 OR count = 2) AND (state = GoNS or state = GoNSL or state=Em) ELSE '0'; --YEW<='1' WHEN (count = 1 OR count = 2) AND (state = GoEW or state = GoEWL or state=Em) ELSE '0'; RNS<='1' WHEN (state = GoEW OR state = GoEWL OR count = 0 OR EmEW ='1' OR EmEWL='1') ELSE '0'; REW<='1' WHEN (state = GoNS OR state = GoNSL OR count = 0 OR EmNS ='1' OR EmNSL='1') ELSE '0'; GNSL<='1' WHEN (state = GoNSL OR EmNSL ='1') ELSE '0'; GEWL<='1' WHEN (state = GoEWL OR EmEWL ='1') ELSE '0'; END Behavior;
process(clk, reset)
begin
if reset = active then
current_state <= idle;
elsif (clk = '1' and clk'event) then
current_state <= next state;
end if
end process;
process(clk, reset)
begin
next_state <= idle;
elsif(clk = '1' and clk'event) then
case(current_state) is
when idle =>
if <condition1> then
next_state <= S1;
else
next_state <= idle;
when S1 =>
if <condition2> then
next_state <= S2
else
next_state <= S1;
when others => null;
end case;
end if;
end process;
Something like this, first process is switching the states and second using to control the machine and decode logic;
good lack
--- Quote Start ---
... the problem is that there are random blips that seem to pop up for no reason. Here's my code and a waveform to show what I'm talkin about.
--- Quote End ---
I can't tell for sure because of the timescale in your waveforms, but it appears that RNS and REW have glitches. These are combinational signals. Combinational signals can glitch unless you carefully design them so that only one LUT or macrocell input at a time can change.
To avoid glitches, you can assert these signals one clock cycle early and pass them through a register. The output of the register will have the timing you originally intended without the glitches.
If you register all your outputs adding one clock cycle of delay for everything, then the relative timing between outputs will be unchanged. You will have an extra clock cycle of latency from input to output, but that might be OK. Your application might not require asserting the combinational signals one clock cycle early to preserve the latency you originally intended.
Right now my clock cycles are too small to really even notice the glitching but it makes the waveform look messy to have it there. I understand what you mean about the signals being combinational but I don't understand what you mean about the signals being passed 1 clock cycle early and having them get put through a register. They are all outside of the process block and they need to know the states of the system. Also since I'm using behavioral vhdl I'm not quite sure how I should put them through a register.
--- Quote Start ---
--- Quote End ---
Let's say you have the sequence of states X, Y, Z, Z1 with each state lasting only one clock cycle and no possible branches to or from other states for this part of the state sequence.
If you want output RNS to be asserted during state Y, you can use "RNS<='1' WHEN (state = Y)". The combinational logic creating the RNS signal might have glitches, but it will otherwise be asserted during the time that the state code equals Y plus the propagation delay to create the RNS signal from the state code.
To avoid glitches on signal RNS, you can instead use "RNS_combinational<='1' WHEN (state = X)" and:
process (Clk) begin if (rising_edge(Clk)) then RNS <= RNS_combinational; end if; end process;
RNS will be the output of a register that is asserted one clock cycle after RNS_combinational. RNS will be asserted while the state code equals Y as originally intended.
When there are state branches, outputs dependent on inputs, states asserted for multiple consecutive clock cycles, etc., the solution is not that simple. But the basic idea still applies that you can assert a state machine output one clock cycle early and pass it through a register to get the timing you originally intended.
--- Quote Start ---
--- Quote End ---
Now let's say you want output RNS to be asserted during state Y and output REW to be asserted during state Z. You could assert RNS_combinational during state X and REW_combinational during state Y so that registered RNS and REW assert during the intended states Y and Z. But if all you really care is that REW assert one clock cycle after RNS, you can leave the RNS_combinational and REW_combinational assertions during the original states Y and Z and let the registered versions assert in clock cycles Z and Z1, one clock cycle later than originally intended. That might be the best solution if things like state branches in the X, Y, Z part of the state machine make it too much trouble to create a way to assert the combinational versions of the signals one clock cycle early.
--- Quote Start ---
--- Quote End ---
If you are synthesizing the VHDL for programmable logic, then it is technically more correct to say that you are using register transfer language (RTL) instead of behavioral VHDL. If you don't write the VHDL in an RTL style that the synthesis tool understands to infer physical device resources like LUTs and registers, you might get poor synthesis results. Use a reference like those mentioned at http://www.alteraforum.com/forum/showthread.php?t=1025 to see examples of acceptable coding styles for things like state machines and registers. You can also get examples from the VHDL templates in the Quartus text editor, which is where I got the template for the register process above.
This looks like a clocking problem, where the atate and counter both change while the clock is active and then the new counter value then causes another state change, then another, then another, etc.
If you are not using an edge triggered state flip flop, it may be the cause.
I am an old designer trying to get up to speed, but it looks like VHDL is too complex to be very useful for this level of abstraction even if it is the only game in town.
I have a prototype that I will not be able to fully develop, but it is on a web site if anyone would care to try it. It is based on a tool that I wrote for my own use then evolved thru C, C+, and now C++.
http://mysite.verizon.net/vzeosqt4/simplesimin
I am attaching a tutorial example FSM counter with the VHDL commented out with // and the input text for my programs at the end so you can see the difference.
//I am including a new testcase here. I coded a VHDL example for a FSM. Hope its interesting.
// -- cocurrent process#1: state registers
// state_reg: process(clock, reset)
// begin
//if (reset='1') then
// current_state <= S0;
//elsif (clock'event and clock='1') then
// current_state <= next_state;
//end if;
// end process;
// -- cocurrent process#2: combinational logic
// comb_logic: process(current_state, a)
// begin
//-- use case statement to show the
//-- state transistion
//case current_state is
// when S0 => x <= '0';
// if a='0' then
// next_state <= S0;
// elsif a ='1' then
// next_state <= S1;
// end if;
// when S1 => x <= '0';
// if a='0' then
// elsif a='1' then
// next_state <= S2;
// end if;
// when S2 => x <= '0';
// if a='0' then
// elsif a='1' then
// next_state <= S3;
// end if;
// when S3 => x <= '1';
// if a='0' then
// elsif a='1' then
// end if;
// when others =>
// x <= '0';
//end case;
// begin
//end if;
// end process;
// begin
// if a='0' then
// end if;
// if a='0' then
// elsif a='1' then
// end if;
// if a='0' then
// elsif a='1' then
// end if;
// if a='0' then
// elsif a='1' then
// end if;
// when others =>
// x <= '0';
//end case;
clk.0 @ 0.2
clk.1 @ 1.2
S0.0 @0
S1.1 @ 0 //Set each state to a unique value because current_state will be set to the appropriate value
S2.2 @ 0
S3.3 @0
a.1 @ 4.6
a.0 @ 5.6
reset.1 @ 4
reset.0 @ 5
\c1?!clk
\c2?clk
current_state:S0 ? (current_state == S3)&a | reset
current_state:S1 ? (current_state == S0)&a
current_state:S2 ? (current_state == S1)&a
current_state:S3 ? (current_state == S2)&a
I started to add a GUI for input, but ran out of gas. Also the output could be made much prettier with maybe netlist output for final design usage.
Hey i have implemented a traffic light controller in the past.. i will advise you to use an ASM, then you can follow the processes and see where isn't functioning properly as required.. Its much easier with ASM.
Also when i designed my counter i used P_count and N_count, e.g:
n_count <= p_count + 1
the problem might be coming from the counters, even though i havnt looked at ur code in details, because as soon as ur counter is wrong, the entire system will be wrong.
Mail me privately if you need my codes...
All the best!
This seems nothing special, very common bahaviour with combinatinal logic - you have to make sure that all physical outs are synched.
