17267 Discussions
Problems with ModelSIM 2020.1 Starter Edition
Gerhard56
I finished the first version of my design and tried to simulate it. Works, but some changes requiered as usual.
Now I have to setup simulation every time from scratch. Defining the clock signal, clock periode and which signals should be in the wave panel.
As my design generate signals using a pwm, it is helpful to use the 'Analog View'. But it is boring to enter the same info over and over.
I searched the documentation how to save this settings, but no success. I only found something to save the results ... pretty fine but not helpful in my situation.
Please help me.
With best regards
Gerhard
ShengN_Intel
Hi Gerhard,
After making any changes to waveform like add signals, choose radix or etc in modelsim, you may save waveform format to reuse by going File -> Save Format. Will default to .do file something like …/project/simulation/modelsim/wave.do.
When you create new simulation, you can reload the waveform format by going to File -> Load -> Macro File and point to the desired .do files.
Best Regards
Sheng
p/s: If any answer from community or Intel support are helpful, please feel free to mark as solution and give Kudos.
Gerhard56
Hi Sheng,
THAAANKS.
Worked as described.
Only one little bump in my road left. This don't restore the settings for my clock signal. I have still to right click at my clock signal and set the periode, because my periode didn't default to 100ns .. I need 83.33ns setting.
But it is much better now.
With best regards
Gerhard
ShengN_Intel
Hi Gerhard,
Ya that method cannot save clock period. Sorry for confusion. For clock period you can declare it in testbench like below example:
`timescale 1ns/1ps
reg clk;
test uut(
.clk(clk));
initial begin
clk = 0;
forever begin
clk = #50 ~clk;
end
end
In this example the clock period is 100ns. You can try with 83.33ns.
Best Regards
Sheng
ShengN_Intel
Hi Gerhard,
Any further update or consideration on this thread or Should I consider the case to be closed?
Sheng
