공지
.jic File Creation
GLees
새로운 기여자 II
873 조회수
I'm using an EP4CE30 device and Quartus Prime Lite version 21.1.0.  When I try to create a .jic programming file the "Configuration Device" selection shows only EPCQL1024.  There are no other choices available.  I'm using an EPCQ64A configuration device.
If I create my .jic file using the EPCQL1024 as my configuration device, my board fails when trying to program it.
0 포인트
1 솔루션
YuanLi_S_Intel
853 조회수
Hi, can you click the ... button beside it? You can select the other configuration device in that option. If the configuration device is not available, you need to create it with the setting. You may refer to link below for the option usage:
https://www.intel.com/content/dam/www/programmable/us/en/pdfs/literature/ug/ug-qpp-gen-flash-programmer.pdf#page=15
원본 게시물의 솔루션 보기
0 포인트
1 응답
YuanLi_S_Intel
854 조회수
0 포인트
응답
