17254 토론
Programmer: Add new CFI Flash Device doesn't work
명예로운 기여자 II
3,890 조회수
Hi there,
I wanted to add a custom Flash device in Programmer (which is listed as compatible (https://www.altera.com/support/support-resources/supported-flash-devices-for-cyclone-v-and-arria-v-soc.html)). So I use right mouse click -> edit -> define cfi flash device and can't find my device in the list (which doesn't surprise in the first place).
https://www.alteraforum.com/forum/attachment.php?attachmentid=15153
So I use the [New] button, fill in my parameters:
https://www.alteraforum.com/forum/attachment.php?attachmentid=15154
(By the way: What's extended device ID? I can't find it in datasheet (https://www.mouser.de/datasheet/2/100/001-98283_s25fl128s_s25fl256s_128_mbit_16_mbyte_25-775474.pdf))
Then I click [OK] aaaand... come back to the first window with nothing changed.
What am I doing wrong?
Thanks in advance.
0 포인트
3 응답
명예로운 기여자 II
2,886 조회수
Can someone help here, or am I really doing an exotic thing nobody else does?
0 포인트
JSwif
초급자
2,886 조회수
I've got the same issue. Did you ever resolve it?
0 포인트
SLabe
Partner
2,886 조회수
If you run Quartus as Adminitrator it should all work well. i.e.:
Note: User flash-defined information is stored in the Windows registry. Therefore, you must have the system administration (administrator) privileges in order to store the parameter in the Define New Flash Device window in the Intel® Quartus® Prime programmer.
0 포인트
응답
