17264 Discussions
Programming 10M02SCU169C8G fails with Programmer 21.1.1.850 but works with ealier versions
frwo
Hi @ll,
I've recently tried to flash a .POF file created for MAX10 (10M02SCU169C8G) using the
Programmer V21.1.1.850 which fails.
Using the Programmer Software V20.1.1.720 (and earlier V18.x.x)
flashing worked as expected.
Using .SOF file worked with all versions.
I also tried compiling and flashing the project for 10M08SCU169C8G setup.
Flashing the .POF and .SOF worked in both cases then!
TLDR;
Programmer V21.1.850 seems to have problems flashing .POF on 10M02SCU169C8G
Fakhrul
Hi frwo,
Sorry for the delay of the response. Could you please provide the error message screenshot?
Fakhrul
frwo
GSica
I discovered that in the latest versions of Quartus Prime Programmer this "trick" curiously works when the programmer refuses to work:
  • Load the Quartus Prima Programmer
  • Do "Auto Detect"
  • Load the file you want to program with the "Change File" button
  • Start programming
In one of my board I have 2 MAX PLD, but different family: one Max5 followed in the same daisy chain by a Max10, If I try to programm the two PLDs in the same operation this doesn't work with the last Quartus Prime Programmer.
Instead doing this operation in two different steps as indicated above and living the other PLD inactive, it works.
But I don't know why...
Giovanni
frwo
I tried your "trick"... but programming still failed here.
Fakhrul
Hi frwo,
I'm not sure this KDB is directly related to your issue, but you may take a look at some of the workaround mentioned here:
Why does programming an Intel MAX 10 device in multiple-device JTAG chain fail with "Error(209012): Operation failed"?
Have you tried to program it on another PC with the same version of Quartus?
frwo
Hi Fakhrul,
please excuse the late feedback.
Enabling "Enable real-time ISP to allow background programming when available"
is fixing the problem but prolongs the flashing considerably.
Moving to another PC did not help!
Fakhrul
As we do not receive any response from you to the previous answer that we provided.
This thread will be transitioned to community support.
If you have a new question, feel free to open a new thread to get support from Intel experts.
Otherwise, the community users will continue to help you on this thread. Thank you
