Programming
Hi!
I'm using a DE2 115 Ciclone IV. I'm trying to program a simple logic (and logic) in the DE2 board but I'm having some problems.
The program and the vhdl are ok, in the compilation everything is fine!
Then, I tried to use the PIN PLANNER, but this is my problem! I put all the input and outputs according to the board's manual (inputs are the buttons, and output is a led) but when I upload the program to the board, it doesn't work!
Am I doing something wrong? Should I do something before the pin planner? Or maybe after?
Please, help me!
tnx
efsuzin
