17268 Discussions
Project a Counter with a Dephased Clock.
I am working in a Project in a Power Eletronic's laboratory and I am stucked in a part of the project. I am suposed to built a high-frequency PWM to get a high resolution in the convertion and I my only ideia does not work.
To explain what I am doing and what I am supposed to do:
I have a counter that counts the range of 0 to 4095 (12 bits) with a frequency of 100Mhz (using a PLL) utilizing the FPGA DE-0 Nano with a clock of 50MHz. Dividing the value of 100Mhz per 4095, I got a number of ~28k, but I need the value of 3 Mhz in this division, so I need to "multiply" my clock of 100 Mhz. The first action is to make the digital circuit counts in the falling edge of the clock, so I double the count of the counter. The second idea that I had it was develop lots of dephased clocks to put in paralel process, but I couldn't make a variable increment on the multiple process.
process(i_clk) begin if rising_edge(i_clk) then -- normal clock acumula <= acumula +1; -- the variable that will be incremented on the two parallel process if acumula = "111111111111" then acumula <= (others => '0'); end if; if acumula = "000000000111" then else s_out_2 <= '0'; end if; end if; end process; process(i_clk_defasado) -- dephased clock begin if rising_edge(i_clk_defasado) then acumula <= acumula +1; if acumula = "111111111111" then acumula <= (others => '0'); end if; if acumula = "000000000111" then s_out_2 <= '1'; else s_out_2 <= '0'; end if; end process;
Help, please! :P
Sorry if I did any language mistake... I am Brazilian!
if I understood you.
you want to divide 100MHz clock into 3MHz.
accumulate 3 modulo 100 i.e:
0+3
3+3
6+3
96+3
99+3 => 2
2+3
5+3
watch count value if < 50 then output '0' else output '1'
This division is fractional and corrects itself on average
No, I want to multiply the quocient of 100mhz/4095 = 28k to 3MHz. It is if I multiply the input clock to 103 times to supply my PWM correctly. Do you got my main idea?
well I don't get it really. Note also 100MHz/4095 = 24.42Khz not 28KHz, am I right?
you mean multiply 100MHz to 100*103 = ??? too fast
But it looks like you eventually want 3MHz clock rate. So the modulo adder I posted should serve same purpose
