Project archiving
Hello from Germany again folks,
I have finished a project and thus need to archive a copy
in order to preserve all my HDL code and top level schematics.
A few details:
I have built all the subblocks in Verilog and then created symbol blocks
which I instatiate in my top level. I then connect all the blocks using
the Quartus II schematic editor.
Here is my problem: Quartus uses an absolute search path in the .qsf file, say we call it HV_CPLD. Once I copy the HV_CPLD to HV_CPLD_4_aug_2010 the library paths in the project still all point to the old directory as do the paths inside the .qsf file.
I have tried using the project -> copy project option, but this does not modify the paths. Do I need to go in and modify all the paths inside the .qsf file by hand ?
There is also the option of archiving the project, but I am not sure that is
what I am looking for either.
What have some of you guys out there done to store old versions of a project ? Would be very thankful for any advice !!
Eric
Quartus archiver should do it. Note that an archive/unarchive will make all the files a sub-directory of the project(you don't want the unarchiver putting files randomly all over a new location), so if that wasn't your original setup then it will look different.
When you add the files in the beginning, you can make them relative, which I recommend.
I'm surprised modifying the .qsf is that difficult. If they're all in one or two locations, a search and replace should do it. I would generally do that since you can see exactly what is done.
