Quartus Block Editor
is it really true that it is not possible to use the quartus block editor with entities which have record types in its ports? To me this seems to be a rather arbitrary limitation.
It would be a pity if there was no way around this, since grouping the signals in records would make schematic more readable and much easier to create in the first place (because i wouldn't have to connect each individual signal).
the way around it is to not use the block editor. The block editor is pretty old and based on AHDL constructs.
