17267 Discussions
Project upgrade from 17.1 to 18.0 failed
YP
I have an soc project created using Quartus 17.1. Windows 10.
Now I want to upgrade the tool to 18.0. When Qsys generates HDL, I got the following error
I have an HPS in my design. I am wondering how to fix this issue? what's the change in HPS from 17.1 to 18.0. ?
Error: border: add_fileset_file: No such file C:/Users/ypeng/AppData/Local/Temp/alt7819_2417341965196273813.dir/0020_border_gen/hps_sdram.v
  while executing
"add_fileset_file [file join $dest_subdir $dest_filename] $file_type PATH [file join $src_fulldir $filename]"
  ("if" then script line 54)
  invoked from within
"if {[lsearch -exact [split $valid_filesets ","] $fileset] != -1} {
if {[regexp {.*\.vh[do]} $filename] } {
set file_type "VHDL"
} elseif {[reg..."
  (procedure "alt_mem_if::util::iptclgen::advertize_file" line 18)
  invoked from within
"alt_mem_if::util::iptclgen::advertize_file $fileset ${sdram_outname}.v $tmpdir {} $fileset"
  ("if" then script line 3)
  invoked from within
"if {[string compare -nocase $fileset "QUARTUS_SYNTH"] == 0 ||
  [string compare -nocase $fileset "SIM_VERILOG"] == 0} {
alt_mem_if::util::iptclg..."
  (procedure "generate_hps_emif_component" line 44)
  invoked from within
"generate_hps_emif_component "hps" QUARTUS_SYNTH"
  ("if" then script line 2)
  invoked from within
"if {[info exists properties(SUPPRESS_SDRAM_SYNTH)] && !$properties(SUPPRESS_SDRAM_SYNTH)} {
  (procedure "synth" line 8)
  invoked from within
"synth system_top_hps_hps_io_border"
I've attached the project created in 17.1. In you open it with 18.0, generate hdl in qsys, you will see the error.
Thanks!
KhaiChein_Y_Intel
Generate HDL completed without error (see attachment). Can you check if my steps are correct?
1) unzip to_intel
2) launch the Intel Quartus Prime Standard Edition software version 18.0 build 614 and open the project
3) open system_top.qsys
4) click 'Generate HDL'
5) HDL generation completed without error.
YP
My team-workers can reproduce the error, so I think it could be some Windows 10 env issue.
KhaiChein_Y_Intel
I tested in Windows10, the HDL generation is successful too.
In the error message, it is mentioned that
Can you check if you have the file saved in directory above?
