17241 Discussions
Pseudo Random Bit generator with VHDL
May anyone give me a hint how to create a Pseudo Random Bit Generator with VHDL and/or Block Diagrams with an ALTERA DE2 Board for a Distance Sensor. The "Random" bits are to be used to generate a set of bits to transmit a supersonic signal through a transducer. The goal is to build a distance meter with VHDL and Block Diagrams through the ALTERA board and QUARTUS.
Francisco
The easiest way would be with a linear feedback shift register: http://en.wikipedia.org/wiki/linear_feedback_shift_register
Here's a PRBS tutorial with source code:
http://www.ovro.caltech.edu/~dwh/correlator/pdf/lfsr_tutorial.pdf
http://www.ovro.caltech.edu/~dwh/correlator/pdf/lfsr_tutorial_src.zip
You can also use a linear chirp signal and pulse compression for distance measurement (even if it is only a 1-bit output).
Cheers,
Dave
--- Quote Start ---
--- Quote End ---
Thank you I'll try it.
Dave, I'm trying to understand and test this code, yet I keep receiving errors do I have to create two separate VHDL files in QUARTUS to run this, one for the testbench and one for the LFSR? When does it mean that is a TESTBENCH? My goal is to generate a random set of bits in order to output a random voltage signal trough the GPIO pins in my DE2 board then I will connect it to a transmitter circuit. This circuit depends on a MOSFET, Resistor, and the transducer. Yet, my first step is understand how to build a LFSR to generate the signal
library IEEE;
use IEEE.STD_LOGIC_1164.ALL;
entity PRNG22 is
generic ( width : integer := 32 );
port (
clk : in std_logic;
random_num : out std_logic_vector (width-1 downto 0) --output vector
end PRNG22;
architecture Behavioral of PRNG22 is
begin
process(clk)
variable rand_temp : std_logic_vector(width-1 downto 0):=(width-1 => '1',others => '0');
variable temp : std_logic := '0';
begin
if(rising_edge(clk)) then
temp := rand_temp(width-1) xor rand_temp(width-2);
rand_temp(width-1 downto 1) := rand_temp(width-2 downto 0);
rand_temp(0) := temp;
end if;
random_num <= rand_temp;
end process;
END Behavioral;
--The test bench for the code is given below:
LIBRARY ieee;
USE ieee.std_logic_1164.ALL;
ENTITY testbench IS
ARCHITECTURE behavior OF testbench IS
--Input and Output definitions.
signal clk : std_logic := '0';
signal random_num : std_logic_vector(3 downto 0);
-- Clock period definitions
constant clk_period : time := 1 ns;
BEGIN
-- Instantiate the Unit Under Test (UUT)
uut: entity work.random generic map (width => 4) PORT MAP (
clk => clk,
random_num => random_num
-- Clock process definitions
clk_process :process
begin
clk <= '0';
wait for clk_period/2;
clk <= '1';
end process;
END
Now I got the code down to 4 errors yet I do not what to change.
library IEEE;
entity PRNG22 is
generic ( width : integer := 8 );
port (
clk : in std_logic;
end PRNG22;
constant clk_period : time = '1' ;
begin
variable temp : std_logic = '0';
clk => clk,
PROCESS_1: process(clk)
begin
end if;
end process PROCESS_1;
begin
clk <= '0';
clk <= '1';
end process;
END Behavioral;
You have messed it up on yourself.
use the original Dave'c code but run the testbench code as top level in your simulator. This testbench will then call up your design as a component.
note also quartus does not support testbench code, use modelsim
Hi Francisco,
--- Quote Start ---
--- Quote End ---
Start by running the existing testbenches.
--- Quote Start ---
--- Quote End ---
Quartus is for *synthesis* only. A testbench is for simulation only, and is run in Modelsim.
If you have written C-code before; you component is equivalent to your C-code, while the testbench is equivalent to a unit test.
--- Quote Start ---
--- Quote End ---
You will not get a random voltage. You will get a stream of 0s and 1s that occur in a random order.
--- Quote Start ---
--- Quote End ---
Make sure your GPIO can drive the MOSFET correctly, eg., a power MOSFET requires more current than a GPIO can supply.
--- Quote Start ---
--- Quote End ---
Simply instantiate the LFSR component.
Here's what you need to do.
1. Start Modelsim. 2. Change directory to where ever you unzipped the zip file Modelsim> cd {c:\temp\lfsr_tutorial_src\prbs} 3. Source the simulation script Modelsim> source scripts/sim.tcl 4. Run the testbench Modelsim> lfsr_tb
Now read the code (VHDL and Tcl scripts), and try to understand it.
Cheers,
Dave
