16624 Discussions
Q14.1 web edition Alt_sld_fab problem
hello guys,i found some problems while using qsys system to build my nios cpu, the problem happens while using jtag-uart, there's no error message about qsys-system-builder, but there's about 5 errors in quartus-builder.
the image is the error happened again.
http://www.alteraforum.com/forum/attachment.php?attachmentid=10434&stc=1
and here is the error message.Error (11176): Generation stopped, 4 or more modules remaining
Error (12154): Can't elaborate inferred hierarchy "sld_hub:auto_hub"
this built environment is quartus II 14.1 web edition
and my system is win8.1 x64 , zh-tw
and building project is "BeMicro MAX 10 FPGA Evaluation Kit"- On-die Temp Sensor (BeMicro)
https://cloud.altera.com/devstore/platform/14.1.0/on-die-temp-sensor-bemicro/
I have been trying the same thing and getting the same error as you described. Have you found a solution to this problem yet? If so, may I ask how you solved it?
Thanks in advance!
