Hi All,
I want to list the Project RTL files in the separate TCL file and then source it from QSF. Here is an example of my TCL file:
set RTL_DIR "D:/units/bit/rtl"
set_global_assignment -library bit_mgr -name QIP_FILE ${RTL_DIR}/fifo/fifo_flr/fifo_flr.qip
set_global_assignment -library bit_mgr -name VHDL_FILE ${RTL_DIR}/pkgs/func/f_and2.vhd
set_global_assignment -library bit_mgr -name VHDL_FILE ${RTL_DIR}/pkgs/func/f_int.vhd
Here is how I source this file inside of QSF: source rtl_files.tcl
But, instead just sourcing this tcl file, Quartus actually copy its contents to QSF. Why? How can I make Quartus to source the tcl file rather than to copy its contents into QSF? Thank you!
