17255 Discussions
QSYS 1st timer -- JTAG to Avalon Master Bridge fails in System Console
Newer user of QSYS and System console here.
I have a JTAG-Avalon master connected as in qsys interconnect picture below. When I try to open service to the only master that is recognized (named phy_0) it fails.
1. Why is the master called phy_0? (I thought it should be master_0 - is this another IP block?
2. Why does to open service fail?
(See second picture of the system-console for commands and hierarchy of what system console is able to "register")
IDEAS? THanks!
Forest
http://www.alteraforum.com/forum/attachment.php?attachmentid=12180&stc=1
http://www.alteraforum.com/forum/attachment.php?attachmentid=12181&stc=1
Could you post your images in a zip file or use a different format? The forum has reduced their size and they are unreadable.
Oh yeah, thanks for pointing that out. clips.zip attached.
