17249 Discussões
QUESTA 2024.1 simulation error
Anpeng
Principiante
1.075 Visualizações
Hi, all !
I encountered an error while using QUESTA 2024.1 for IP simulation, and I would like to know where the issue lies. Below are the steps I took:
1. generate simulator script set up for ip
2. Writing a *.do file within the document path.
3. Running a *.do file in Questa.
4. The following error warnings appeared:
By the way, while I was compiling the simulation library, the following errors also occurred:
BRs,
Anpeng
Etiquetas (1)
1 Solução
KennyTan_Altera
Moderador
1.037 Visualizações
I believe there is a missing steps in your design. Can you follow the steps in https://www.intel.com/content/www/us/en/docs/programmable/691278/21-3/prerequisites.html and let me know if does not work?
I have tested this example design and it works.
Ver solução na publicação original
5 Respostas
KennyTan_Altera
Moderador
1.038 Visualizações
KennyTan_Altera
Moderador
984 Visualizações
Is there any update?
Anpeng
Principiante
975 Visualizações
I have solved the problem, thank you very much!
KennyTan_Altera
Moderador
906 Visualizações
I’m glad that your question has been addressed, I now transition this thread to community support. If you have a new question, Please login to ‘https://supporttickets.intel.com/s/?language=en_US’, view details of the desire request, and post a feed/response within the next 15 days to allow me to continue to support you. After 15 days, this thread will be transitioned to community support. The community users will be able to help you on your follow-up questions.
KennyTan_Altera
Moderador
906 Visualizações
Responder
