17245 Discussions
QUESTION on Signal Assignment of same signal and measuring times in FPGA.
Dear all,
can you tell me if the following is an illegal statement in VHDL 2008. I want to count up a signal read_pointer synchronously but I am not sure if the signal assignment of the same signa plus 1 will correctly synthesized:
address_pointer : process(CLK, RESET_H) begin if (RESET_H = '0') then read_pointer <= (others => '0'); elsif (rising_edge(CLK)) then read_pointer <= read_pointer + '1'; end if; end process address_pointer;
Or do I have to make a buffering signal like this read_pointer <= read_pointer_mem + 1 and then behind the process read_pointer_mem <= read_pointer?
And I do have one further question:
What is the best way to measure a span of time in FPGA. I want to measure the span of time between two data packets. My idea was to count just the clk_cycles between the packets. Are the other ways?
Thank you.
Yes - use a counter to measure time, in clock cycles. That's how I would do it.
As for your code - fundamentally it's about right. What signal type are you proposing for 'read_pointer'? Depending on what that is will determine whether you need single quotes around the '1'. I'd suggest using an 'unsigned' type or an integer with a positive range. Then you wouldn't put single quotes around your + 1.
Whether you need a 'buffer' signal depends whether 'read_pointer' in a output port to your entity. You can't read output ports. So, if so, you'd need a local buffer which you'd increment and also assign to the relevant output port.
Cheers,
Alex
This post has no VHDL 2008 code, unless you are using numeric_std_unsigned or numeric_bit_unsigned to allow the addition of a vector and a bit/std_logic (that you are doing in the code) (but I dont think quartus supports those libraries yet).
This is really a question of logic, rather than code standard, and I think Alex has covered it.
