17261 Discussions
Qaurtus automatically include files without using `include directives ?
kikoss
New Contributor II
Hello
Has Quartus a have a built-in feature to automatically include files without using `include directives in our Verilog source.
Must we  explicitly specify the files to be included using  `include in the Verilog code. ?
if a have a 3rd part IP where this is the case (they didnt used `include explicetely ) how should we expect to compile that on quartus ? (the 3rd part dont provide an altera version of the IP )
Thx
Kikoss
kikoss
New Contributor II
@ShengN_Intel  it's a lot of work to give a minimal design based on the IP we have to compile
However, seems we found some of the issues:
Some issues were related to the fact that:   The `include xyz.sv is not forwarded across the hierarchy, contrary to the VCS compiler, so the solution was to add those `include and import the specific package that's defined on the `include
Another issue was related to the timescale: we removed it from the top-level design and
Thx for everyone about the advice
sstrell
Try adding the files to the project (Project menu -> Add/Remove Files).
ShengN_Intel
Other ways will be make sure the include package or file at the directory where .qpf resides. Or set the library path.
Sheng
kikoss
New Contributor II
Hello
it didn't worked ..
i want to make sure the issue is well described :
The issue is that there are some structs defined on a specific file let say fileA
Those structs are used on project files , let say fileB
fileA name is not included on fileB (by 3rd parts vendor IP  - asic vendor , they don't  provide quartus version)
on asic (vcs also ) flow its compiled well - by adding the location of fileA only
on quartus , it didnt compiled , so  i add the following : set_global_assignment -name SEARCH_PATH <fileA directory location >
but , quartus  get error : that the struct (defined  on fileA) is not declared
I tried what you suggests , to copy the file on .qpf directory , but still the same error ..
ShengN_Intel
Possible to provide a minimal design for better understanding and testing?
Sheng
kikoss
New Contributor II
