17259 Discussions
Qsys Custom Component Problem
I am experiencing a problem using Qsys while adding a custom component into
a design and wanted to ask if others have seen this issue. I have run three
experiments to link in a custom component using both SOPC and Qsys under
Quartus II V11.1. One of the Qsys methods still fails.
The experiments are as follows:
1) Using SOPC and adding the new core by instantiating it in the top level
HDL source. Here, I add the Avalon MM-Slave used to link the new component
to NiosII in the SOPC System and link the I/O ports provided in the System
module to the new core within the top level HDL source file. The PLL is
also instantiated at the top level providing both a fast cpu clock and a
slow peripheral clock. The slow peripheral clock is used by multiple
SOPC peripherals and the new core. With this configuration, I can
successfully access the new core's registers.
2) Using Qsys and adding the new core by including the top level HDL file when
creating the custom component. The PLL is instantiated at the top level,
but the new core is not. This version also allows for successful access
to the new core's registers.
3) Using Qsys and adding the new core by instantiating it in the top level
HDL source. This version does not work. Just like the SOPC version, the
Avalon MM-Slave is configured to export the I/O ports needed to link the new
core at the top level. The Qsys generation does correctly place these I/O
ports in the system module. The PLL is also instantiated at the top level.
When running this version, the NiosII cpu and other peripherals that use
the slower clock still work, but the new core's registers are not accessible.
I always read 0's from the core's control register. As a small experiment,
I tried disconnecting the reset to the new core in case that was a problem.
That still didn't work.
My conclusion's at this point are that either Qsys no longer allows for the
core to be instantiated from the top level, I'm still making a mistake in
how I've tried to configure the MM-Slave's ports to the top level, or
Qsys has a problem. If Qsys is intended to still allow for the capability
to instantiate custom cores at the top level, I would still like to
pursue getting this to work that way.
By default conduit interfaces are not exported to the top. Click the 'export as' column beside your component in the GUI and name the interface you want to shoot up to the top.
Actually, I had already named the conduits for the three interfaces where I want the
signals exported to the top. The greyed-out "Click to Export" text no longer appears
there. After running generation, the signals as I named them do appear on the
Qsys module.
using QSys, sometimes changes to components do not appear on the system contents. "F5" refreshes the system and reloads latest changes. Maybe generation also refreshes it.
Right the changes to the top level do not take effect until you generate the system.
You can see the potential port changes prior to generation by using the "HDL Example" tab. You can verify that your ports are exported.
(At least this is my experience with Qsys in 11.1)
I'm certian that the custiom core in question is being included in the overall FPGA build.
I do see the ports I've configured it for in the Qsys "HDL Example" tab. I've also opened
the verilog source that Qsys generates and can see the ports defined there with the
appropriate bus widths. I've re-run Qsys generation after each time that anything was
changed in the Qsys configuration.
When building the three of the examples that I mentioned, all of them report virtually the
same device utilization for the custom core.
I've narrowed down the issue to a problem with Qsys.
After setting up SignalTap, I learned that the resulting Avalon Bus cycle is not lasting as
long as expected. The custom core creates a two clock bus cycle by deasserting the waitrequest_n
(high) on the second clock cycle. When viewing the Avalon bus cycle in SignalTap, it shows that
chipselect and write are going inactive prior to the deassertion of the waitrequest_n control.
Since the actual register writes occur one clock cycle after the deassertion of the waitrequest_n
control while chipselect is still active, no register writes are occurring. Hence the registers
always reads back as zero's.
When viewing the bus cycle in the Custom Component editor, it indicates that chipselect does
not deassert until one clock cycle after waitrequest_n deassertion. However Qsys is not
working that way in the system and interprets the signal as being a positive active waitrequest.
To get the design running, I modified the top level hdl source by inverted the waitrequest_n
signal from the new core before routing it back to the Qsys module. Now the registers are
accessable and the core runs.
According to the Avalon 2.0 spec:
When present, a slave port ignores all Avalon-MM signals unless
chipselect is asserted. chipselect must be used in
combination with read or write. The chipselect signal is not
necessary; Altera does not recommend using it.
Also when you created the component you mapped your waitrequest to the type "waitrequest_n" and not "waitrequest" right?
Yes, read or write must be requested (and not changed either ways) independent from waitrequest, because the subtle trap I got I would like you to confirm is that they must not be deasserted before the waitrequest is granted or else it will be granted afterwards and it locks the bus!
That's correct. If a master de-asserts read or write in the middle of a transaction that is being extended due to waitrequest being asserted then the spec is not being followed (and if you simulate this an assertion should occur).
When I set up the custom component, the MM-Slave interface includes the signals
writedata, readdata, address, chipselect, write, and waitrequest_n. It also
has interfaces for the clock and reset. Under the signals tab, the waitrequest_n
signal name was assigned to the MM-slave interface, assigned the waitrequest_n
signaltype, and assigned as an output. When observing the behavior with SignalTap,
waitrequest_n behaves as if it is waitrequest. I've attached a SignalTap trace
of the failing bus cycle. Both the chipselect and write signals are truncated
to a single clock cycle.
If I rebuild the design after modifying the top level hdl by inverting the
waitrequest_n signal from the instantiation of the new core before sending it
back to the Qsys system instantiation, then the bus cycle works correctly. In
that configuration, both chipselect and write signals have a duration of two
clock cycles as expected since the new core deasserts waitrequest_n (high) at
the begining of the second clock cycle.
During this process, I have been working with my distributor's FAE. He was able
to reproduce the same incorrect behavior on the waitrequest_n signal using a
completely different experimental design than I have. After that, I submitted a
Service Request to Altera and am awaiting their response.
Perhaps the GUI isn't poking the right value into the .tcl file for your component. If you open up the .tcl file for it and search for that waitrequest_n signal it should have "waitrequest_n" listed beside it. If that's not the case manually edit that line so that the right signal type is present which should remove the need to hack the generated HDL.
The *.tcl file created for the custom component does list the waitrequest_n
signal type. I suspect the problem may be beyond that point during generation
of the Qsys module.
The reponse I received from my Service Request is that this potential bug is
being passed to the Qsys engineering team for investigation.
For now, this issue is not holding up any product development for me. This was
mainly an exersice to practice with a development board, practice with Qsys, and
prove the new core's operation in a system. To continue, I can either use
my experiment option# 2 or the waitrequest_n signal inversion in option# 3.
A fourth option would be to use waitrequest and invert it within your logic that way you don't need to hack up the generated HDL. The Qsys fabric internally uses waitrequest so I'm guessing the bug you are seeing is the inverter in the translation block is missing.
Today I confimed that Quartus II V12.0 corrects this problem in Qsys with incorrect polarity being used for waitrequest_n.
