17267 Discussions
Qsys project re-generate issue(PCIe in Qsys for StratixIVGX)
Hi guys,
I just download the example project(PCIe in Qsys for StratixIVGX) from wiki, and open Qsys to generate it again, I didn't change anything. However, i got this errors
http://www.alteraforum.com/forum/attachment.php?attachmentid=9824&stc=1
It seems powerdown signal in primary project is float, these error tell me to export this signal outside Qsys and connect to somewhere. My QII version is 12.1+sp1. My question is why this happens when i re-generate?
This is simple:
As the error already says: Export them!
To put it quick: if you do not use a port in QSYS, export it to the "Outside". There you can connect it to Ground, Vcc or other logic.
For the powerdown-ports especially you can invert the PCIe_reset_n and use it as Input to powerdown. As I know this is also the way it's done in the Altera design example.
PS: for good digital design: EVERY input has to be connected to something. For example if you don't use some Inputs of an OR-Gate, wire them to ground. If you don't use some Inputs of an AND-Gate, wire them to Vcc. Inputs which are "dangling in the Air" produces unexpected behaviour.
--- Quote Start ---
This is simple:
--- Quote End ---
Hi Steffen,
Thanks for you reply, it's OK now! The next step is to add my own fifo inside Qsys.
I've made a screenshot of my exported ports of PCIe outside of QSYS.
--- Quote Start ---
--- Quote End ---
I got it, thank you very much.
