Quartus 10.0 bug?
Hi again Guys,
I have a little issue. Attached file compiles fine with Q 10.1, however on Q 10.0 I'm getting following warnings after analysis and synthesis:
Info: Elaborating entity "rom1" for the top level hierarchy
Warning (10873): Using initial value X (don't care) for net "datar" at rom1.vhd(18)
Warning (10873): Using initial value X (don't care) for net "datai" at rom1.vhd(19)
Warning: Output pins are stuck at VCC or GND
Warning (13410): Pin "datar[0]" is stuck at GND
Warning (13410): Pin "datar[1]" is stuck at GND
Warning (13410): Pin "datar[2]" is stuck at GND
Warning (13410): Pin "datar[3]" is stuck at GND
Warning (13410): Pin "datar[4]" is stuck at GND
Warning (13410): Pin "datar[5]" is stuck at GND
Warning (13410): Pin "datar[6]" is stuck at GND
Warning (13410): Pin "datar[7]" is stuck at GND
Warning (13410): Pin "datar[8]" is stuck at GND
Warning (13410): Pin "datar[9]" is stuck at GND
Warning (13410): Pin "datar[10]" is stuck at GND
Warning (13410): Pin "datar[11]" is stuck at GND
Warning (13410): Pin "datar[12]" is stuck at GND
Warning (13410): Pin "datar[13]" is stuck at GND
Warning (13410): Pin "datar[14]" is stuck at GND
Warning (13410): Pin "datar[15]" is stuck at GND
Warning (13410): Pin "datai[0]" is stuck at GND
Warning (13410): Pin "datai[1]" is stuck at GND
Warning (13410): Pin "datai[2]" is stuck at GND
Warning (13410): Pin "datai[3]" is stuck at GND
Warning (13410): Pin "datai[4]" is stuck at GND
Warning (13410): Pin "datai[5]" is stuck at GND
Warning (13410): Pin "datai[6]" is stuck at GND
Warning (13410): Pin "datai[7]" is stuck at GND
Warning (13410): Pin "datai[8]" is stuck at GND
Warning (13410): Pin "datai[9]" is stuck at GND
Warning (13410): Pin "datai[10]" is stuck at GND
Warning (13410): Pin "datai[11]" is stuck at GND
Warning (13410): Pin "datai[12]" is stuck at GND
Warning (13410): Pin "datai[13]" is stuck at GND
Warning (13410): Pin "datai[14]" is stuck at GND
Warning (13410): Pin "datai[15]" is stuck at GND
Info: Generating hard_block partition "hard_block:auto_generated_inst"
Warning: Design contains 11 input pin(s) that do not drive logic
Warning (15610): No output dependent on input pin "clk"
Warning (15610): No output dependent on input pin "address[0]"
Warning (15610): No output dependent on input pin "address[1]"
Warning (15610): No output dependent on input pin "address[2]"
Warning (15610): No output dependent on input pin "address[3]"
Warning (15610): No output dependent on input pin "address[4]"
Warning (15610): No output dependent on input pin "address[5]"
Warning (15610): No output dependent on input pin "address[6]"
Warning (15610): No output dependent on input pin "address[7]"
Warning (15610): No output dependent on input pin "address[8]"
Warning (15610): No output dependent on input pin "address[9]"
Info: Implemented 43 device resources after synthesis - the final resource count might be different
Info: Implemented 11 input pins
Info: Implemented 32 output pins
Info: Quartus II Analysis & Synthesis was successful. 0 errors, 47 warnings
Info: Peak virtual memory: 258 megabytes
Info: Processing ended: Fri Nov 4 13:47:16 2011
Info: Elapsed time: 00:00:10
Info: Total CPU time (on all processors): 00:00:10
It seems to be a Q 10.0 bug. Did you experienced this before?
Q10 was a bit buggy
Any reason you have to use Q10? you already said it worked in 10.1. How about Q11?
agreed, i highly recommend walking away swiftly from 10.0
I got it, thanks a lot guys.
