- 新着としてマーク
- ブックマーク
- 購読
- ミュート
- RSS フィードを購読する
- ハイライト
- 印刷
- 不適切なコンテンツを報告
Has any one else seen this?
Q 11.1 incorrectly compiles the design. When trying the same code, qsf, sdc and rest of the project with Q 11.0 sp1, the design is compiled correctly. I do not see any timing errors in Q 11.1 compile. At present, the only way I can tell that the design doesn't function is by seeing ip hdr chksum errors on the network sniffer. Any pointers, suggestions while I continue to debug this? Thanks. Sanjayコピーされたリンク
3 返答(返信)
- 新着としてマーク
- ブックマーク
- 購読
- ミュート
- RSS フィードを購読する
- ハイライト
- 印刷
- 不適切なコンテンツを報告
I suggest you try to build in a signal tap to examine and try to isolate what's failing.
So far I haven't had any issues with 11.1 but it may be very specific issue with the code you are compiling. If you can isolate it down to a single section of code, that's in error, you can open a service request to see if you can get a hotfix for it. I would also double check any false path statements. It may be that the timing across a "false Path" is really critical, and the to routers just placed the logic differently, causing it to run or fail. Pete- 新着としてマーク
- ブックマーク
- 購読
- ミュート
- RSS フィードを購読する
- ハイライト
- 印刷
- 不適切なコンテンツを報告
Everyone using 11.1 should add the following patch:
http://www.altera.com/support/kdb/solutions/rd11182011_10.html
