Hello.
I am trying to use Quartus V11.0 (without sp1) for Stratix-IIGX. When I am trying to create ALT2GXB block for SONET/SDH, it do not let to change the input clock frequency (see image, "What is the image clock frequency"). What is the cause for such situation and what can I do to create a correct SDH/SONET block? There is no such problem for ALTGX and Stratix-IV. My OS is Windows-7 64 bit. Thank you in advance.Link Copied
UPD.
There is no such problem in Quartus V8. Will sp1 for Q11 help me?- Mark as New
SP1 haven't helped to me :(.
Any news on this problem?
I have an issue with a clk freq that used to compile on Quartus 9 but not on 11.- Mark as New
have you tried 11.1sp1?
I've solved this (and further) problems by migrating to Quartus 9.1.
This and previous versions are working good with Stratix-IIGX, 10 and later have bugs. Last version I've tryed was 11.0sp1. 11.1 hangs even without SIIGX :(. (didn't tryed 11.1sp1)
