Hello -
I have a DE2 board, a Terasic TRDB-D5M camera, and a Terasic TRDB-LTM display board. I can run the DE2_D5M_LTM demonstration software & the camera and board work as advertised. When I try to open the associated DE2.qpf project file, I get the following errors: Error: Error reading Quartus II Settings File C:/Documents and Settings/Scott Christensen/Desktop/Terasic/3InOne/DE2_D5M_LTM_testing/DE2.qsf, line 534 Info: set_global_assignment -name LL_IGNORE_IO_BANK_SECURITY_CONSTRAINT OFF -section_id "CCD_Capture:u3" Error: Error reading Quartus II Settings File C:/Documents and Settings/Scott Christensen/Desktop/Terasic/3InOne/DE2_D5M_LTM_testing/DE2.qsf, line 536 Info: set_global_assignment -name LL_IGNORE_IO_BANK_SECURITY_CONSTRAINT OFF -section_id "Sdram_Control_4Port:u7" I wrote Terasic this morning but haven't heard back. Has anyone had a similar problem? I used both Quartus 7.2 and 9.1 software and received similar errors. Thanks a bunch. ScottLink Copied
