17268 Discussions
ModelSim -> Error: xxxxx.vhd(n): Library yyyy not found
I'm trying to run an RTL Simulation of a project using the NativeLink set-up in Quartus II. But I end up with the following error: (in red)
--- Quote Start ---
Reading C:/altera/11.0sp1/modelsim_ase/tcl/vsim/pref.tcl
# do GrabReader_run_msim_rtl_vhdl.do
# if {[file exists rtl_work]} {
# vdel -lib rtl_work -all
# vlib rtl_work
# vmap work rtl_work
# Copying c:\altera\11.0sp1\modelsim_ase\win32aloem/../modelsim.ini to modelsim.ini
# Modifying modelsim.ini
# ** Warning: Copied c:\altera\11.0sp1\modelsim_ase\win32aloem/../modelsim.ini to modelsim.ini.
# Updated modelsim.ini.
# vcom -93 -work work {C:/qdesigns/c-cam/bb/vhdl_packages/CC_Data_Types.vhd}
# Model Technology ModelSim ALTERA vcom 6.6d Compiler 2010.11 Nov 2 2010
# -- Loading package standard
# -- Loading package std_logic_1164
# -- Loading package numeric_std
# -- Loading package math_real
# -- Loading package lpm_components
# -- Compiling package cc_data_types
# -- Compiling package body cc_data_types
# -- Loading package cc_data_types
# vcom -93 -work work {C:/qdesigns/c-cam/bb/gates/regmux/regmux.vhd}
# ** Error: C:/qdesigns/c-cam/bb/gates/regmux/regmux.vhd(7): Library cc_data_types not found.
# ** Error: C:/qdesigns/c-cam/bb/gates/regmux/regmux.vhd(8): (vcom-1136) Unknown identifier "cc_data_types".
# ** Error: C:/qdesigns/c-cam/bb/gates/regmux/regmux.vhd(11): VHDL Compiler exiting
# ** Error: c:/altera/11.0sp1/modelsim_ase/win32aloem/vcom failed.
# Error in macro ./GrabReader_run_msim_rtl_vhdl.do line 9
# c:/altera/11.0sp1/modelsim_ase/win32aloem/vcom failed.
# while executing
# "vcom -93 -work work {C:/qdesigns/c-cam/bb/gates/regmux/regmux.vhd}"
--- Quote End ---
So Modelsim doesn't seem to find a package in a lower module, although it had no problem locating it just a bit earlier.
If I run the Gate Level Simulation everything runs OK, except that I don't get a clock running. genclk : process begin Clk <= '0' ; wait for TClChClk ; Clk <= '1' ; wait for TClChClk ; end process genclk ;
For building Lower level modules a Gate Level Simulation is not really necessary, so I tried the RTL Simulaton.
Any clues?
The error:
can probably be resolved by
vmap cc_data_types rtl_work
I suspect that in the regmux code you have
library cc_data_types;
use cc_data_types.cc_data_types.all;
or something like that.
Modelsim is expecting to find these data types in that library, whereas your script compiles them into 'work'.
Alternatively you can
vlib cc_data_types
vmap cc_data_types cc_data_types
vcom -93 -work cc_data_types {C:/qdesigns/c-cam/bb/vhdl_packages/CC_Data_Types.vhd}
Or something pretty close to that ...
Cheers,
Dave
Hi Dave,
--- Quote Start ---
--- Quote End ---
Spot on! It is in about every VHDL code I write nowadays. I have another package like that.
The idea was to have the 'NativeLink' do it all for me ... (kind of like the 'euthanized' Internal Quartus Simulator where one clicked Run Simulation and waited for the result waveform to show up)
Apart from that do you have a clue why I can't get the clock to work, Gate Simulation runs fine, i.e. ModelSim shows a waveform, but I don't see the generated Clk signal toggle at all.
Josy
Hi Josy,
--- Quote Start ---
--- Quote End ---
It is good coding practice to use libraries. Modelsim is nice enough to allow precompiled libraries, so having 'library' code (stuff you do not touch once it is working) compiled into a library is nice, since it you do not need to recompile it.
--- Quote Start ---
--- Quote End ---
I tend to treat Modelsim and Quartus as completely independent tools, and control each with Tcl scripts. I have never used Nativelink, and am unlikely to try it :)
--- Quote Start ---
--- Quote End ---
What is the variable getting set to? Try adding this code:
assert false report "Clock half period is " & time'image(TClChClk) severity note; Cheers,
Dave
Hi Dave,
Unfortunately I tend to 'augment' my main library on almost a daily basis. So it would be nice to automate ModelSim a bit.
--- Quote Start ---
--- Quote End ---
I see the difference, but then I 'grew up' with MaxPlusII and Quartus, at first without the II and I have a hard time separating. The reflex still is to code in QuartUS II and run it through the internal simulator. But as you indicate I could easily write the (low-level) code in an external editor, e.g. Sigasi, use ModelSim to do the RTL-simulation, and later integrate it all in Quartus II or Qsys, and as I rarely simulate a top level file,as to my idea one shouldn't have to, I'd be finished.
I'll try the assertion later.
Josy
Hi Josy,
--- Quote Start ---
--- Quote End ---
Tcl is definitely the way to go to automating Modelsim.
--- Quote Start ---
--- Quote End ---
I did too. Having to manually create waveforms in the the Max+PlusII simulator led me to start using Modelsim.
I guess you were just more patient than me :)
--- Quote Start ---
--- Quote End ---
I create components in a lib/ folder. Each component has its own folder, and testbench. The testbench can be run via a 'make check' Makefile, so that if I edit a component and break others, I find out reasonably soon ('make check' is run on all testbenches in the lib/ folder). These components can then be used in higher level designs, eg., a Qsys system. I typically include an Avalon-MM BFM in those systems, and then write a basic testbench to check everything is working. All my lib/ code is in VHDL, whereas the Qsys stuff needs to use SystemVerilog ... so Modelsim full-edition is required. I'll write an Avalon-MM BFM in VHDL one of these days ...
Cheers,
Dave
Hi Dave,
--- Quote Start ---
--- Quote End ---
I ran my first successful ModelSim simulation yesterday (on a lazy Sunday afternoon ...) and you are quite right (as usual) generating repetitive signals is quite easy and very neat.
I used the native link in QII and that runs fine. Today I decided to continue on the momentum and tried to simulate the other part of the project. So I went through exactly the same motions, copy-paste-edited some of the first testbench into the second. Started the (gate-level) simulation but got this error:
--- Quote Start ---
# ** Error: (vsim-13) Recompile work.iddramread because work.iddramread_data_type has changed.
# ** Error: (vsim-13) Recompile work.iddramread(structure) because work.iddramread_data_type has changed.
--- Quote End ---
I use the std_logc_2D type (defined in lpm_pack.vhd) a lot and the testbench-writer adds a package at the top of the testbench to define local types for these ports to use while simulating.
Any clue(s)?
Josy
--- Quote Start ---
--- Quote End ---
Glad to hear it!
--- Quote Start ---
# ** Error: (vsim-13) Recompile work.iddramread because work.iddramread_data_type has changed.# ** Error: (vsim-13) Recompile work.iddramread(structure) because work.iddramread_data_type has changed.
--- Quote End ---
Its not so much an 'error' in the sense of a coding error as it is a dependency error. Modelsim is telling you that you edited and rebuilt a package, but did not then recompile the components that use (depend on) that package.
What is missing in some of these tools is the ability to create a dependency list from .vhd files. Modelsim has a tool called vmake which can create this list from a working design, but I'd really like something that can take a list of .vhd files in a directory and figure out the build order from scratch.
Take a look at vmake to get your dependencies figured out for now.
I'll probably write a Tcl script to figure out dependencies in general, but I won't have time to do that just yet.
If anyone has a .vhd dependency generator, I'd like to hear about it.
Cheers,
Dave
--- Quote Start ---
--- Quote End ---
The odd thing is that this 'package' is sitting in the testbench file itself, so I can not see how it would go out of sync.
I did a third project (combining the other two) and that simulated fine with QII0.1SP2 but not with the webversion 11.0SP1. I tried the new VHDL-2008 unconstrained std_logic_vector arrays, but then QII stil generates a xxx_data_type package. And ModelSim chokes on those unconstrained types as well when runnung RTL simulation where it compiles the source code itself, even when I set the 2008 flag. So the only way out may be the 'wide' std_logic_vector but then we might as well start using Verilog ...
--- Quote Start ---
--- Quote End ---
Don't forget though that Modelsim keeps a copy of the intermediate build files in subdirectories under 'work'. If you are copying-and-pasting, you are potentially creating duplicates of the same packages. I would expect that'll lead to problems. You should change your mindset to think like a programmer; reusable stuff goes in headers and libraries.
--- Quote Start ---
--- Quote End ---
Simulated? You mean synthesized? Or are you talking about Modelsim ASE that comes with each of these versions?
--- Quote Start ---
--- Quote End ---
I haven't run across this particular problem. Why is Quartus generating code? Is this for a post-P&R simulation? Can you post a simplified example?
Cheers,
Dave
--- Quote Start ---
--- Quote End ---
I deleted the work directories ... no change
--- Quote Start ---
--- Quote End ---
Gate Level simulation, after P+R. Using the Altera supplied Modelsim executables (ASE).
Actually I tried a small project to see how the Test Bench Writer (11.0sp1) would handle the unconstrained std_logic_vector. I attach a .qar. I included the std_logic_2D version in the .qar for reference.
Josy
Hi Josy,
--- Quote Start ---
--- Quote End ---
Ok, I see a project and source, but no simulation script.
How do you go about simulating this design in Modelsim? I typically use a sim.tcl script to build all the components and create Tcl procedures for the testbench, eg., I just posted a simple example in this thread:
http://www.alteraforum.com/forum/showthread.php?t=32386
But I want to know what you are doing, so I can reproduce the error you see.
Cheers,
Dave
Hi Dave,
I use the Nativelink: go to Tools-> Run EDA Simulation Tool -> EDA Gate Level Simulation
It will produce a .do script on the fly I believe.
Josy
Hi Josy,
--- Quote Start ---
--- Quote End ---
Ok, I got a chance to look at the design again tonight. The machine I am working on has 10.1 installed, but the design bombs out looking for array_of_slv, I uncommented the CC_data_types.vhd line
Type array_of_slv is array (natural range <>) of std_logic_vector ;
which Quartus is ok with, but Modelsim ASE doesn't like it.
I'll try it tomorrow on my other machine which has 11.0sp1 installed and see if I can get to the error you were seeing.
Cheers,
Dave
Hi Dave,
It was ModelSIm choking on the std_logic_2D as well, I didn't try compiling the array_of_slv with Modelsim as I was using Gate Level simulation anyway and using the QII generated testbench with the 'funny' types.
Anyway I just worked my way around the one project by making a test-project and generate some data in there to drive the dut and then ran the internal simulator. After that I finished the 'real' project (combining this and another subproject plus a bunch of M4K) under Modelsim, again using Gate Level simulation.
I noticed that the Altera Modelsim version is only 6.6d where Mentor have 10.0c out. Maybe that version has decent VHDL 2008 support? But then we would have to spend some additional money.
I'll have to find the time to study your 'script' setup more closely, but I have to find a solution/workaround for my 'legacy' std_logic_2D code as well.
Thanks for all the support,
Josy
Modelsim 10+ has very good 2008 support.
--- Quote Start ---
--- Quote End ---
How come Altera make us do with 6.6d then? Do they have a deal with Mentor to seed a 'teaser'?
Its always been like that. The altera version is only updated once every couple of years.
WARNING:
Even though the latest release of Modelsim could be better, its not always compatible with the Quartus simulation IP.
I had a case where the altsyncram RAM simulation model provided with Quartus only worked correctly with the version of Modelsim that shipped with that version of Quartus.
Here's my notes from the testbench I submitted as part of the SR:
-- -- 1. This testbench works fine when run from Modelsim ALTERA 6.1g -- (ships with Quartus 7.2 and 8.0) -- -- However, with Modelsim SE 6.3f, it fails. Writes to the RAM -- show valid output data after the 2 clock pipeline, but then -- the data goes to unknown state - even if the address does -- not change. Byte-enables were asserted during reads, and it -- made no difference. The 'solution' was to use only a compatible version of Modelsim. (I never have looked at the difference between altsyncram components to see if the code was actually changed ...).
Cheers,
Dave
--- Quote Start ---
--- Quote Start ---
--- Quote End ---
--- Quote End ---
--- Quote Start ---
--- Quote End ---
Perhaps an apology is on order: Quartus II 11.1 comes with ModelSim ASE 10.0c!
--- Quote Start ---
The error:
vlib cc_data_types
Cheers,
Dave
--- Quote End ---
Apparently the thing to do is to use the 'work' as the container for user packages also.
--library CC_Data_Types ; -- use CC_Data_Types.CC_Data_Types.all ; library work ; use work.CC_Data_Types.all ; This keeps the ModelSim link happy, and Quartus is fine with it too. (I suppose I used the 'use library' in a non-standard way. I never understood this VHDL library idea anyway ..)
--- Quote Start ---
--- Quote End ---
Argh, that's a horrible thing to do :)
Do you rebuild the lpm library, and altera_mf library, etc., every time you run Modelsim? No of course you don't. How then does Modelsim Altera know about these libraries ... through the magic of library mappings.
Think of Modelsim libraries as shared object libraries, like a DLL or .so file.
When you build a C program or C++ program, you link against the shared library, you do not build it each time.
The same analogy holds for Modelsim libraries (whether the language be VHDL or Verilog - VHDL just happens to be more specific about their use).
I don't have 10.0c installed just yet, but I'd be extremely surprised if library mapping is somehow broken :)
Library mappings are stored in modelsim.ini or in the project file .mpf. I personally don't use .mpf files, since you cannot change directory in the Tcl shell. If you type the command 'where' or 'echo $env(MODELSIM)' it will tell you where the library mapping file is. Open that file and look at the top section [Library], and you will see all the mappings.
vmap fred [pwd]/fred
will edit that file and create a mapping to the library fred. Now you can compile into that library via
vcom -work fred <some code>
or delete the mapping via
vmap -del fred
But the delete will only work if the library mapping is still working correctly ($env(MODELSIM) points to what it thinks is the mapping file). If the original modelsim.ini file the variable MODELSIM points to was read-only, modelsim copies it to your local folder as modelsim.ini, and then changes the variable MODELSIM to simply modelsim.ini (i.e., a relative path, rather than an absolute path). If you cd away from the folder containing the copy of modelsim.ini, then the library mappings will not be visible anymore (since MODELSIM uses a relative path, and modelsim.ini does not exist in the folder you just changed to). I find this feature rather annoying. Perhaps you have just stumbled on it too.
Cheers,
Dave
